Audiosource Amps and Preamp
smglbrth
I am wanting to upgrade and was wondering if anyone would be interested.
I have two Audiosource Amp One/A's, which have been bridged for mono channels the whole time I've had them. They are rated at 80 watts/channel in stereo and 200 watts/channel in mono. I've had them for under a year and they both are in great condition and they've always had plenty of room to breathe.
The second is an Audiosource Pre One/A preamplifier. Six line level inputs, no phono input though. Condition is the same for the preamp as the amps and I've had it darn near the exact same amount of time.
I do have all the boxes and instruction manuals.
I'd like to get $160/each for the amps and $100 for the preamp.
As for the shipping that would be a flat $15 for each unit.
If you want to see them go to www.audiosource.net . I don't have a digital camera or I'd post it here, sorry about that.
If you'd like to email me, it's smglbrth@bytehead.com .
Thanks!
Thanks!
Post edited by smglbrth on
Forgot to mention as well that I also have an Onkyo T-4000 tuner. $45 or so would take this.
The above prices I stated are what I'd like to receive but you can make an offer, as long as it's not rediculously low.
If I don't hear from anyone within a couple of days I'll list them on Ebay.
Yes, I've got the upgrade itch....:DRemember, when you're running from something, you're running to something...-me -
Where are you located? Do those amps have the 2 ch level control on the front? I can't remember which Audiosource models did and didn't.
FYI, not only are those amps heavy, and good 2ch amps, bridged they make GREAT sub amps.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Rooster,
Yes, they do have the 2 volume/gain nobs on the right front. Since I used them as monoblocks I only used the right control and they do sound darned good for 2 channel as well!
About the weight, you are correct. For their small size they have a decent heft of about 15 lbs, must the toroidal transformer. I like to call these the carb transformers since that's what the look like.
Thanks for your input!Remember, when you're running from something, you're running to something...-me -
Rooster,
Forgot to tell you my location, Wisconsin, the Lake Michigan side.Remember, when you're running from something, you're running to something...-me
