Audiosource Amps and Preamp
smglbrth
smglbrth Posts: 1,502
edited March 2003 in Flea Market
I am wanting to upgrade and was wondering if anyone would be interested.
I have two Audiosource Amp One/A's, which have been bridged for mono channels the whole time I've had them. They are rated at 80 watts/channel in stereo and 200 watts/channel in mono. I've had them for under a year and they both are in great condition and they've always had plenty of room to breathe.
The second is an Audiosource Pre One/A preamplifier. Six line level inputs, no phono input though. Condition is the same for the preamp as the amps and I've had it darn near the exact same amount of time.
I do have all the boxes and instruction manuals.
I'd like to get $160/each for the amps and $100 for the preamp.
As for the shipping that would be a flat $15 for each unit.
If you want to see them go to www.audiosource.net . I don't have a digital camera or I'd post it here, sorry about that.
If you'd like to email me, it's smglbrth@bytehead.com .
Thanks!
Post edited by smglbrth on
  • smglbrth
    edited March 2003
    Forgot to mention as well that I also have an Onkyo T-4000 tuner. $45 or so would take this.
    The above prices I stated are what I'd like to receive but you can make an offer, as long as it's not rediculously low.
    If I don't hear from anyone within a couple of days I'll list them on Ebay.
    Yes, I've got the upgrade itch....:D
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2003
    Where are you located? Do those amps have the 2 ch level control on the front? I can't remember which Audiosource models did and didn't.
    FYI, not only are those amps heavy, and good 2ch amps, bridged they make GREAT sub amps.
    Cheers,
    Rooster
  • smglbrth
    edited March 2003
    Rooster,
    Yes, they do have the 2 volume/gain nobs on the right front. Since I used them as monoblocks I only used the right control and they do sound darned good for 2 channel as well!
    About the weight, you are correct. For their small size they have a decent heft of about 15 lbs, must the toroidal transformer. I like to call these the carb transformers since that's what the look like.
    Thanks for your input!
  • smglbrth
    edited March 2003
    Rooster,
    Forgot to tell you my location, Wisconsin, the Lake Michigan side.
