Started work on a RCM(Record Cleaning Machine
BaggedLancer
BaggedLancer Posts: 6,371
edited January 2008 in DIY, Mods & Tweaks
Well, I decided to take the FUBAR elac turntable I had an convert it into a record cleaning machine. So far I built the arm onto the table with a spring on the underside to hold it firm and level on the vinyl. I used felt( i have probably 20 yards of brand new felt here) to make the brush, it's about 3/4" wide. Hopefully today I make it out to go find myself some sort of hand pump with tubing to make a vinyl cleaning solution dispenser.
Yes, I realize it looks like crap, but it works great, it holds nice and level on the vinyl and it's a good recycling project for that old turntable. This has no vacuum so I will be making another arm to go after it passes under the felt, probably of microfiber to do the drying.
Here is a crappy video of it in action. This was just a crap test vinyl I had on there, when it's done I obviously will turn the machine off before i slide the arm off.
Post edited by BaggedLancer on
  • Face
    Face Posts: 14,340
    edited January 2008
    Didn't someone want that table for parts? :D
  • BaggedLancer
    edited January 2008
    Face wrote: »
    Not many parts left.......:p
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    Cool man! You are well on your way to saving bucu bucks and if you do it right and execellent wet/vac.
  • BaggedLancer
    edited January 2008
    Here is sort of a cool idea for the solution delivery system......still fooling around with it, but you get the idea
  • BaggedLancer
    edited January 2008
    Oh yea, feel free to make negative comments on what should be fixed/adjusted, etc. I know this looks like a hunk of junk, but it works at the moment and it's cheaper than buying the VPi machine.
  • Face
    Face Posts: 14,340
    edited January 2008
    Be sure to have that thing out of sight when you have chickies over.
  • BaggedLancer
    edited January 2008
    Face wrote: »
    Oh stop...they will love it. I'm posting pics of it on facebook.
  • hearingimpared
    edited January 2008
    I'm very impressed. I can't wait to see how you resolve the vacuum portion.
  • BaggedLancer
    edited January 2008
    Vacuum I'm kinda stumped, any ideas? I would prefer a small unit with a hose, people suggested to use a shop vac but those things are so damn loud.
  • Face
    Face Posts: 14,340
    edited January 2008
    Who cares how loud it is as long as it works. It'll evaporate quicker than a small vac could pick it up.
  • hearingimpared
    edited January 2008
    A shop vac will suck the grooves off the record!!!!
  • unc2701
    unc2701 Posts: 3,587
    edited January 2008
    You can by the vacuum arm assemblies from VPI:
    http://www.vpiindustries.com/prices.htm
    I'd recommend that since the price isn't too bad and it might be difficult to make that part yourself. As for the vac, you can get a smaller shopvac, or maybe a car vacuum.
    Backburner:Krell KAV-300i
  • BaggedLancer
    edited January 2008
    $120 is way too much for a vacuum. At that point I might as well just buy the whole thing used for $400
  • unc2701
    edited January 2008
    Not the motor- just the arm- looks like $26- $60 depending on the model.
