Started work on a RCM(Record Cleaning Machine
BaggedLancer
Well, I decided to take the FUBAR elac turntable I had an convert it into a record cleaning machine. So far I built the arm onto the table with a spring on the underside to hold it firm and level on the vinyl. I used felt( i have probably 20 yards of brand new felt here) to make the brush, it's about 3/4" wide. Hopefully today I make it out to go find myself some sort of hand pump with tubing to make a vinyl cleaning solution dispenser.
Yes, I realize it looks like crap, but it works great, it holds nice and level on the vinyl and it's a good recycling project for that old turntable. This has no vacuum so I will be making another arm to go after it passes under the felt, probably of microfiber to do the drying.
Here is a crappy video of it in action. This was just a crap test vinyl I had on there, when it's done I obviously will turn the machine off before i slide the arm off.
Post edited by BaggedLancer on
Didn't someone want that table for parts?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Cool man! You are well on your way to saving bucu bucks and if you do it right and execellent wet/vac.
Oh yea, feel free to make negative comments on what should be fixed/adjusted, etc. I know this looks like a hunk of junk, but it works at the moment and it's cheaper than buying the VPi machine.
Be sure to have that thing out of sight when you have chickies over."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Oh stop...they will love it. I'm posting pics of it on facebook. -
I'm very impressed. I can't wait to see how you resolve the vacuum portion.
Vacuum I'm kinda stumped, any ideas? I would prefer a small unit with a hose, people suggested to use a shop vac but those things are so damn loud.
Who cares how loud it is as long as it works. It'll evaporate quicker than a small vac could pick it up."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
A shop vac will suck the grooves off the record!!!!
You can by the vacuum arm assemblies from VPI:
http://www.vpiindustries.com/prices.htm
I'd recommend that since the price isn't too bad and it might be difficult to make that part yourself. As for the vac, you can get a smaller shopvac, or maybe a car vacuum.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
$120 is way too much for a vacuum. At that point I might as well just buy the whole thing used for $400
Not the motor- just the arm- looks like $26- $60 depending on the model.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
