RM6880 Subwoofer Question
jpc22819
Do I need to hook up my front speakers to the sub
Post edited by jpc22819 on
Welcome to the forum.
You can wire either front's via the sub(Polk way), or wire them direct, and use the 'sub-out' channel on your rcvr, with an RCA cable. You'll have to determine which sounds better to you.
If this didn't answer your question, please add more info/ detail
Good luck.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
