RM6880 Subwoofer Question
jpc22819
jpc22819 Posts: 2
Do I need to hook up my front speakers to the sub
Post edited by jpc22819 on
  • obieone
    obieone Posts: 5,077
    edited January 2008
    Welcome to the forum.
    You can wire either front's via the sub(Polk way), or wire them direct, and use the 'sub-out' channel on your rcvr, with an RCA cable. You'll have to determine which sounds better to you.
    If this didn't answer your question, please add more info/ detail
    Good luck.
