12v trigger cable
NeilGabriel
I need a 12 v trigger cable that terminates in bare wire (or spades) to connect to the amp that I want to trigger. I can't find any online. Anyone have a link? Thanks much.
Can you just take a regular cable and make your own, cut the end and either use the bare wires or attach whatever interconnect you'd like?
I agree with Mike, just buy an 1/8" mono cable, and strip one end to bare wires. Worked fine on my old Rotel.
Yep...did that same thing for my Parasound 7100 and 2205 amp...worked great!THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
I have the 2205A (parasound)....so the trigger only connects to one point on the amp? next to the ground? thanks a lot.... -
NeilGabriel wrote: »I have the 2205A (parasound)....so the trigger only connects to one point on the amp? next to the ground? thanks a lot....
Yup...just like WilliamM2 posted...once you strip the jacket off of the 1/8" mono cable, you'll see two wires. Twist up each wire and connect on the back of the amp (see lower left hand trigger connections in pic).
Connect the other end to your pre/pro and make sure the trigger power options are configured in the menu options of your pre/pro.THE SYSTEM
Make certain that you purchase a Cardas silver 12-volt trigger cable. <kidding>
I needed jumpers for my NAD receiver, and I ordered them from NAD at $1.67 a piece (plus 20 bucks shipping). Cardas had upgrades for $80....a pair though! I think......
http://www.dedicatedaudio.com/inc/sdetail/5274
