12v trigger cable
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2008 in Electronics
I need a 12 v trigger cable that terminates in bare wire (or spades) to connect to the amp that I want to trigger. I can't find any online. Anyone have a link? Thanks much.
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2008
    Can you just take a regular cable and make your own, cut the end and either use the bare wires or attach whatever interconnect you'd like?
  • janmike
    janmike Posts: 6,146
    edited January 2008
    Try Radio Shack.
    Michael ;)
    NORTH of 60°
  • WilliamM2
    WilliamM2 Posts: 4,829
    edited January 2008
    I agree with Mike, just buy an 1/8" mono cable, and strip one end to bare wires. Worked fine on my old Rotel.
  • Ethancf
    Ethancf Posts: 481
    edited January 2008
    WilliamM2 wrote: »
    Yep...did that same thing for my Parasound 7100 and 2205 amp...worked great!
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • NeilGabriel
    edited January 2008
    Ethancf wrote: »
    I have the 2205A (parasound)....so the trigger only connects to one point on the amp? next to the ground? thanks a lot....
  • Ethancf
    Ethancf Posts: 481
    edited January 2008
    Yup...just like WilliamM2 posted...once you strip the jacket off of the 1/8" mono cable, you'll see two wires. Twist up each wire and connect on the back of the amp (see lower left hand trigger connections in pic).
    Connect the other end to your pre/pro and make sure the trigger power options are configured in the menu options of your pre/pro.
    THE SYSTEM
  • rskarvan
    rskarvan Posts: 2,374
    edited January 2008
    Make certain that you purchase a Cardas silver 12-volt trigger cable. <kidding>
  • NeilGabriel
    edited January 2008
    rskarvan wrote: »
    I needed jumpers for my NAD receiver, and I ordered them from NAD at $1.67 a piece (plus 20 bucks shipping). Cardas had upgrades for $80....a pair though! I think......
    http://www.dedicatedaudio.com/inc/sdetail/5274
