Save some energy??
Ricardo
SOPA
SOPA
Post edited by Ricardo on
I actually find it easier to read."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
IIRC, a black screen on LCDs uses more power because the cells are swtiched on to block the backlight.
John in MA wrote: »IIRC, a black screen on LCDs uses more power because the cells are swtiched on to block the backlight.
Just leave your SDA's and amps off for a couple years...that will save enough energy to make up for the Club Polk users with LCD's using Blackle.
Thanks. -
Admitted, as a partially blind mo-fo, it is easier to read. I'll give it a whirl Ricardo.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
BaggedLancer wrote: »Just leave your SDA's and amps off for a couple years...that will save enough energy to make up for the Club Polk users with LCD's using Blackle.
Thanks.
You should see the 295 amp arc welder I have parked in the garage. Runs off a 50A breaker subpanel. -
It's still google... Just with their own first page and black and silver...
What's the point?? -
I have my puter at work and home set up kinda like this because it`s easier on the ol eyeballs..
Kinda kool that I can have it pre-set by googlie..!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Polk addict wrote: »It's still google... Just with their own first page and black and silver...
What's the point??
What's your point?_________________________________________________
Not all of google's features work correctly. I'm probably going back."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
