sonosub project, all hints and suggestions appreciated
13»
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    I told you to go with a shorter port...but Noooooooo, you had to go long...:mad::p:D
    Congrats. Changing the fronts to small probably helped some phase issues, shorting the port made the sub more efficient.
    Great job.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • station10fd
    station10fd Posts: 45
    edited January 2008
    jakelm wrote: »
    Great job.
    Short port, short sono.............I'm cursed:eek:
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Dont worry Station, as long as it does the job, size doesnt matter. Some of us guys just have ours alittle longer. But if your little stubby one works for you, go with it.:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • station10fd
    edited January 2008
    What ya got to sell?
    I'm lost :confused:
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    I think it had more to do with the configuration of the AVR/Pre Pro over the lenght of the port. Ihad the same driver, and the shorter port sucked. I had to switchback to the long port. Just run the thing for a while before you start tunning it!!! Also What Amp are you currantley using?
    Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    ben62670 wrote: »
    Ben
    +1
    Also room nulls and peaks will be the biggest "say so" in the journey of tweaking. What might sound good in one corner , might sound like crap in another.
    I think he said he was using a Buttkicker amp. I noticed , that sub amps need alittle more "playing" time before they are broken in.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • station10fd
    edited January 2008
    ben62670 wrote: »
    Ben
    Yes, I think I'm done messing with it for a while. I'm very happy with it now. I've got a couple extra couplings, so I can go back longer. I'm using the buttkicker 1000 watt till I can get the dayton. Did you get my PM ben?
    Mike T.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    I remember when I bought my Rythmik plate amp, it didnt sound good at all, but 15 hours later, it sound great.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    F1nut Posts: 51,771
    edited January 2008
    I'm lost :confused:
    LOL.....you have to keep up Mike, things move fast here. Dustradio was on a posting rampage, so that he could get the required 25 to post a for sale ad, which rightfully so, has been deleted. Thanks JB.
  • station10fd
    edited January 2008
    ahhhhhhh, ok, I'm slow, but I'm learning!
    F1nut Posts: 51,771
    edited January 2008
    :D You're doing fine.
