DIY subwoofers
hoosier21
I built stereo subwoofers, each tower has 4 12" drivers each. Here is the thread where I discussed them.
http://www.polkaudio.com/forums/showthread.php?t=31077&highlight=subwoofer
Here is a picture of one subwoofer.
http://www.polkaudio.com/forums/attachment.php?attachmentid=10899&d=1126217988
Willing to sell the pair for 800.00 including the Beringher BFD. Basically 100.00 per driver. I can ship these via truckline but is $$$.
Or, if I can sell drivers in lots of 4 (either 1 person buys 4 or multiple buys taking 1-2-3 of them) Drivers 100.00 each plus shipping
Willing to talk about most any deal you can come up with, always interested in trades, but cash is KING.
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
Us?..
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
New Year Day bump.
These drivers are great for car subs also.
Make an offer, I am in a good mood
How low do they go?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Specs for the drivers
Atlas 12"
Low Qts Specs
Fs 23.2 Hz
Qms 4.9
Qes .354
Qts .33
Vas 128.5 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 481 cm2
Mms 119 g
Vd 1.73 L
RMS Power 300 watts
BL 11.7
Spl 1W/1M 88.5 dB
Spl 2.83V/1M 92.6 dB
Le .86 mH
Cms .395 mm/N
No. .442
Cutout 11.125"
Diameter 12.5"
Depth 6.5"
Weight 21 pounds
Mid Qts Specs
Fs 23.2 Hz
Qms 4.9
Qes .465
Qts .415
Vas 128.5 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 481 cm2
Mms 119 g
Vd 1.73 L
RMS Power 300 watts
BL 10.2
Spl 1W/1M 87.2 dB
Spl 2.83V/1M 91.4 dB
Le .86 mH
Cms .395 mm/N
No. .336
Cutout 11.125"
Diameter 12.5"
Depth 6.5"
Weight 21 pounds
High Qts Specs
Fs 23.2 Hz
Qms 4.9
Qes .581
Qts .52
Vas 128.5 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 481 cm2
Mms 119 g
Vd 1.73 L
RMS Power 300 watts
BL 9.1
Spl 1W/1M 86.3 dB
Spl 2.83V/1M 90.5 dB
Le .86 mH
Cms .395 mm/N
No. .271
Cutout 11.125"
Diameter 12.5"
Depth 6.5"
Weight 21 poundsDodd - Battery Preamp
How low do they go?
I am not sure Brad, I have a test CD I use for setting them up and it goes to 20, I use the EQ to make them as fat as possible in my horrible basement room. The drivers are each in a 1 cubic foot box sealed from eachother. This makes a very tight bass, but with the smaller cabinet for each driver means you have to boost the extreme lowend, I use the beringher for that. I wired the drivers so I have 4 ohms in each cabinet. This produces serious bass, I get 20 hz with huge output when asked.Dodd - Battery Preamp
was toying with another projectDodd - Battery Preamp
wow those looks awesome. I would totally buy those from you if you were localReceiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340 -
Wow...
I need to stop visiting the flea market
I go away for 5 days and come back to find something I dont need!
Wow, Ill walk away and see if they are still here -- I see you once a year, so... ol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How did you wire the subs for a final Impedance to the amp ( Series/Parallel Combo) . I usually go for a 4 ohm final when using multiple woofers for home...nice job by the way.The first rule of Fight Club is you don't talk about Fight Club
Badass....
If Russ getting good bass in his room (I've NEVER heard a worse room for bass)....in YOUR room, it'll hit the brown note without breaking a sweat.
shadowofnight wrote: »How did you wire the subs for a final Impedance to the amp ( Series/Parallel Combo) . I usually go for a 4 ohm final when using multiple woofers for home...nice job by the way.
Assuming they are 8 ohm/sub, you wire each pair in parallel to get 2-4 ohm circuits then put those 2 circuits in series.
If they are 4 ohms each, then you do the opposite. Put 2 subs in series, then put those 2 pair in parallel.
3 subs would be a bit more complicated.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
they are 4 ohm,Dodd - Battery Preamp
Nice! Real Nice!
Nice! Real Nice!
Starting to rethink selling them, too much work and cash in them, plus they kick ****.Dodd - Battery Preamp
Yeah, good idea. Hold onto them until I'm able to purchase them.;)
In the meantime, design & build an external crossover (or use a Behringer) and top off the subs with a couple of mid/tweet modules. That would be cool.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Russ,, they look absolutey beautiful.:)JC approves....he told me so. (F-1 nut)
what kind of power and crossover would you need for this? I have an amp but not sure if it'll handle 4 ohm mono...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Will these sound good with a HT?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
Wes
Silly rabbit...I know how to do it...I do it on a weekly sometimes daily basis
I was just wondering what he WANTED his final impedance to be...load wise for the amplifier he used and what the future owner needed to plan for. The first rule of Fight Club is you don't talk about Fight Club -
Unless you're planning on building something bigger and badder, I'd hold onto them."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I Wish You Live In NjReceiver - Onkyo HT-R340
ok, I am in sell mode again on these subs.
Really these are local only, as shipping costs are too frigging much as I found out last time.
800.00 including the Beringher BFD, OBO.Dodd - Battery Preamp
I'll throw them in my suburban and deliver to the lucky buyer.Dodd - Battery Preamp
Oh, so NOW you want to sell them.
As an aside, these look and sound fantastic....a STEAL at the price.
Russ I have moved to Guam but I'd like for you to deliver the subs. Please fill your tank and head my way........JK
Those would be cool to use down on the basement rig.
ChuckTesting
Testing
Testing -
stereo_luver wrote: »Russ I have moved to Guam but I'd like for you to deliver the subs. Please fill your tank and head my way........JK
Chuck
I was refering to local delivery
Just let me know when you want them.Dodd - Battery Preamp
Come on ladies, don't be afraid of these monsters
I can make a great deal on the two bass arrays, Beringher, Outlaw electronic crossover and Adcom 565 power amps.Dodd - Battery Preamp
Russ, just hit the 'gon - they'll sell for twice as much, in half the time.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
