DIY subwoofers
hoosier21
hoosier21 Posts: 4,418
I built stereo subwoofers, each tower has 4 12" drivers each. Here is the thread where I discussed them.
http://www.polkaudio.com/forums/showthread.php?t=31077&highlight=subwoofer
Here is a picture of one subwoofer.
http://www.polkaudio.com/forums/attachment.php?attachmentid=10899&d=1126217988
Willing to sell the pair for 800.00 including the Beringher BFD. Basically 100.00 per driver. I can ship these via truckline but is $$$.
Or, if I can sell drivers in lots of 4 (either 1 person buys 4 or multiple buys taking 1-2-3 of them) Drivers 100.00 each plus shipping
Willing to talk about most any deal you can come up with, always interested in trades, but cash is KING.
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
  • DeusExa
    DeusExa Posts: 491
    edited December 2007
  • hoosier21
    DeusExa wrote: »
    Us?..
    What are you asking?
  • hoosier21
    edited January 2008
    New Year Day bump.
    These drivers are great for car subs also.
    Make an offer, I am in a good mood :)
  • Early B.
    Early B. Posts: 7,900
    edited January 2008
    How low do they go?
    "God grooves with tubes."
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Those are sexy. What drivers are they?
  • hoosier21
    edited January 2008
    Specs for the drivers
    Atlas 12"
    Low Qts Specs
    Fs 23.2 Hz
    Qms 4.9
    Qes .354
    Qts .33
    Vas 128.5 L
    Re 2.8 ohms
    Znom 4 ohms
    Xmax 18 mm
    Sd 481 cm2
    Mms 119 g
    Vd 1.73 L
    RMS Power 300 watts
    BL 11.7
    Spl 1W/1M 88.5 dB
    Spl 2.83V/1M 92.6 dB
    Le .86 mH
    Cms .395 mm/N
    No. .442
    Cutout 11.125"
    Diameter 12.5"
    Depth 6.5"
    Weight 21 pounds
    Mid Qts Specs
    Fs 23.2 Hz
    Qms 4.9
    Qes .465
    Qts .415
    Vas 128.5 L
    Re 2.8 ohms
    Znom 4 ohms
    Xmax 18 mm
    Sd 481 cm2
    Mms 119 g
    Vd 1.73 L
    RMS Power 300 watts
    BL 10.2
    Spl 1W/1M 87.2 dB
    Spl 2.83V/1M 91.4 dB
    Le .86 mH
    Cms .395 mm/N
    No. .336
    Cutout 11.125"
    Diameter 12.5"
    Depth 6.5"
    Weight 21 pounds
    High Qts Specs
    Fs 23.2 Hz
    Qms 4.9
    Qes .581
    Qts .52
    Vas 128.5 L
    Re 2.8 ohms
    Znom 4 ohms
    Xmax 18 mm
    Sd 481 cm2
    Mms 119 g
    Vd 1.73 L
    RMS Power 300 watts
    BL 9.1
    Spl 1W/1M 86.3 dB
    Spl 2.83V/1M 90.5 dB
    Le .86 mH
    Cms .395 mm/N
    No. .271
    Cutout 11.125"
    Diameter 12.5"
    Depth 6.5"
    Weight 21 pounds
  • hoosier21
    edited January 2008
    Early B. wrote: »
    How low do they go?
    I am not sure Brad, I have a test CD I use for setting them up and it goes to 20, I use the EQ to make them as fat as possible in my horrible basement room. The drivers are each in a 1 cubic foot box sealed from eachother. This makes a very tight bass, but with the smaller cabinet for each driver means you have to boost the extreme lowend, I use the beringher for that. I wired the drivers so I have 4 ohms in each cabinet. This produces serious bass, I get 20 hz with huge output when asked.
  • hoosier21
    edited January 2008
    was toying with another project
  • Phasearray
    Phasearray Posts: 437
    edited January 2008
    wow those looks awesome. I would totally buy those from you if you were local
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
    VR3 Posts: 29,437
    edited January 2008
    Wow...
    I need to stop visiting the flea market
    I go away for 5 days and come back to find something I dont need!
    Wow, Ill walk away and see if they are still here -- I see you once a year, so... ol
  • shadowofnight
    shadowofnight Posts: 2,735
    edited January 2008
    How did you wire the subs for a final Impedance to the amp ( Series/Parallel Combo) . I usually go for a 4 ohm final when using multiple woofers for home...nice job by the way.
    The first rule of Fight Club is you don't talk about Fight Club
  • TroyD
    TroyD Posts: 13,124
    edited January 2008
    Badass....
    If Russ getting good bass in his room (I've NEVER heard a worse room for bass)....in YOUR room, it'll hit the brown note without breaking a sweat.
    BDT
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2008
    Assuming they are 8 ohm/sub, you wire each pair in parallel to get 2-4 ohm circuits then put those 2 circuits in series.
    If they are 4 ohms each, then you do the opposite. Put 2 subs in series, then put those 2 pair in parallel.
    3 subs would be a bit more complicated.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • hoosier21
    edited January 2008
    they are 4 ohm,
  • c019740
    c019740 Posts: 11
    edited January 2008
    Nice! Real Nice!
  • hoosier21
    edited January 2008
    c019740 wrote: »
    Nice! Real Nice!
    Starting to rethink selling them, too much work and cash in them, plus they kick ****.
  • Early B.
    edited January 2008
    hoosier21 wrote: »
    Yeah, good idea. Hold onto them until I'm able to purchase them.;)
    In the meantime, design & build an external crossover (or use a Behringer) and top off the subs with a couple of mid/tweet modules. That would be cool.
  • george daniel
    george daniel Posts: 12,096
    edited January 2008
    Russ,, they look absolutey beautiful.:)
  • Toxis
    Toxis Posts: 5,116
    edited January 2008
    what kind of power and crossover would you need for this? I have an amp but not sure if it'll handle 4 ohm mono...
  • MrNightly
    MrNightly Posts: 3,370
    edited January 2008
    Will these sound good with a HT? :D
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • shadowofnight
    edited January 2008
    I-SIG wrote: »
    Wes
    Silly rabbit...I know how to do it...I do it on a weekly sometimes daily basis :) I was just wondering what he WANTED his final impedance to be...load wise for the amplifier he used and what the future owner needed to plan for.
  • Face
    Face Posts: 14,340
    edited January 2008
    Unless you're planning on building something bigger and badder, I'd hold onto them.
  • Phasearray
    edited January 2008
    I Wish You Live In Nj
  • hoosier21
    edited February 2008
    ok, I am in sell mode again on these subs.
    Really these are local only, as shipping costs are too frigging much as I found out last time.
    800.00 including the Beringher BFD, OBO.
  • hoosier21
    I'll throw them in my suburban and deliver to the lucky buyer.
  • TroyD
    TroyD Posts: 13,124
    Oh, so NOW you want to sell them.
    As an aside, these look and sound fantastic....a STEAL at the price.
    BDT
  • Systems
    Systems Posts: 14,873
    hoosier21 wrote: »
    Russ I have moved to Guam but I'd like for you to deliver the subs. Please fill your tank and head my way........JK
    Those would be cool to use down on the basement rig.
    Chuck
    Testing
    Testing
    Testing
  • hoosier21
    Chuck
    I was refering to local delivery ;)
    Just let me know when you want them.
  • hoosier21
    Come on ladies, don't be afraid of these monsters :)
    I can make a great deal on the two bass arrays, Beringher, Outlaw electronic crossover and Adcom 565 power amps.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Russ, just hit the 'gon - they'll sell for twice as much, in half the time.
