Need help on Banana Plugs
Atrocity
Atrocity Posts: 20
I have a question about using banana plugs. I'm getting the Onkyo TX-SR705 receiver. And thinking of picking up the Emotiva LPA-1 amp. I'm new to HT and using an external amp. I'm a bit confused on the wiring that would need to take place. Basically its from the Onkyo's preouts to the Emotiva amp. All speakers would need to be plugged into the Emotiva amp and not to the receiver itself, correct? So can I use banana plugs from the Emotiva to the speakers. I read the manuals of CSi5, FXi3's, and the RTi10's and it says to use banana plugs I need to carefully pry out the binding post plugs. I can not find a rear view of the Emotiva amp so I don't know for use if banana plugs can be used with it. As for the number of banana plugs needed if I can use them on the Emotiva I would need 2 plugs for each speaker for a total of 10 banana plugs. Correct me if I'm wrong.
Post edited by Atrocity on
    F1nut Posts: 52,301
    edited December 2007
    I'd be very surprised if the amp doesn't accommodate banana pins. If it doesn't, for some reason, use spades.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    I am pretty sure that almost any decent amp accommodates either bananas or spades, and it the amp you are looking at doesn't, it isn't decent.
  • Atrocity
    Atrocity Posts: 20
    For some reason I just can't find a rear picture of the Emotiva. I'm going to search some more for a picture or just email them for confirmation.
    Am I write about how it all needs to connected? Onkyo preouts > Emotiva amp > Speakers.
  • acsubie
    acsubie Posts: 773
    the LPA has 5 way binding post that easily accomodates bannana plugs, as for the number you need 20 total for a 5 speaker setup, 2 for each amp side(+/-) side and 2(+/-) for each speaker side
    as for the plugs,try these, never come off and very well built
    http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=locking
  • zingo
    zingo Posts: 11,258
    Bananas should work fine, almost all high end equipment accommodates them.
  • Atrocity
    Atrocity Posts: 20
    zingo wrote: »
    I like the way those cables look on that Z Cables site.
  • apphd
    apphd Posts: 1,514
    Atrocity try this:
    http://http://www.emotiva.com/expandedpages/lpa1expanded.html
    It shows the front and rear of the LPA1 very good. They are out of stock right now, and there may be a price increase or at least an end to the year end sale price coming, but you can still lock in the sale price if you order soon.
  • Atrocity
    Atrocity Posts: 20
    apphd wrote: »
    Atrocity try this:
    Thanks for the pics. Just what I needed but now I'm confused. From the Onkyo's preouts to the amp would go on the top row or bottom row? I'm thinking Onkyo> Emotiva bottom row> Top row plugs to speakers. But I could be wrong and I think I am.
  • meanuc
    meanuc Posts: 7
    top row to onkyo, bottom row to speakers. Top row is RCA plugs to preamp outs on Onkyo.
  • mhartman29
    mhartman29 Posts: 257
    I'm sure this is a dumb question, but what's the best way to pry the plugs out of the binding posts? I tried pulling one out of my RT3000s and I'm afraid I'm going to damage the binding post.
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
    Signal Analog II ICs
    Signal Ultra speaker cables
  • Atrocity
    Atrocity Posts: 20
    mhartman29 wrote: »
    That was my next question. The word "pry" when dealing with these speakers has a bit hesitant. Anybody know if this easy to achieve?
    Also does anyone know where I can find a diagram of how the wiring is done from the receivers preouts to a 5 channel amp?
  • apphd
    apphd Posts: 1,514
    Are you going to be running: 5 - 6 - or 7 ch?
  • apphd
    apphd Posts: 1,514
    I may be wrong but I think with the LPA1 you could run: the mains (R&L), center, and L&R surrounds through ch 1-5. Or run that set up with ch 6&7 on the LPA1 bridged and run a rear (6.1) @ 125W or run the first set up (ch 1-5) with 6&7 unbridged for a 7.1 setup with the R&L rear surrounds on ch 6&7 @ 50W each.
  • tcrossma
    tcrossma Posts: 1,301
    Atrocity wrote: »
    Banana plugs should pull out fairly easily. There should be no need to "pry" them out unless the plugs were the wrong size for the speakers, or maybe have become corroded in there???
    As to a diagram, I think you're making this more confusing than it needs to be. If your receiver has a "pre-out" section, that section will have one RCA connector for each channel. Simply connect an "interconnect" cable from each of those connectors to one of the RCA connectors on your amp.
    Your amp then has speaker connectors (5-way binding posts), one for each channel. This is where you run the "speaker cable" to your speakers.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    F1nut Posts: 52,301
    He's asking about removing the plastic plugs from the center of the binding posts, not actual banana plugs.
    Anyway, just pry them out with a very small screwdriver or needle nose pliers. You're not going to damage the posts.
  • Atrocity
    Atrocity Posts: 20
    Thanks everybody for the replies. Sorry for the confusion. I got confused when someone said I needed 20 cables. So now I need to look for the interconnect cable that will go from the receivers preouts to the amp and then the speaker cables. 1 interconnect cable and 10 banana plugs.
  • jabrax
    jabrax Posts: 315
    Atrocity wrote: »
    Not quite - you need 5 interconnect cables or 2 1/2 pairs. You need 1 interconnect per preout for each channel to the amp.
    I have the LPA1 - do the following
    you need 1 cable for each of the following preouts from the onkyo
    front R - 1 cable to #1 channel on amp (speaker cables below to your R speaker)
    front L - 1 cable to #2 channel on amp (speaker cables below to your L speaker)
    center - 1 cable to #3 channel on amp (speaker cables below to your center channel speaker)
    Follow the same pattern for your surrounds. -
    Good luck - if it gets really painful PM me and I give you my number to call if ya need.
    Jeff
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • vonnie123
    vonnie123 Posts: 326
    mhartman29 wrote: »
    Check to see if you have locking bananas. Turn the banana plug housing to the left, and it will release if you have lockings. When the plugs are turned clockwise the banana exands to hold it inside the 5 way binding post.
    I prefer spades. They make better contact and are less likely to pull out from the amp or speaker selector. With heavier cables, the bananas tend to work themselves loose on my setup.
    F1nut Posts: 52,301
    Once again.....
  • vonnie123
    Once again.....
    thanks F1. I saw that after I posted. I hadn't read all the posts prior to the clarification on the red and black plastic center pieces. Have a great evening.
  • mjwilliams45
    mjwilliams45 Posts: 18
    Yea, if I'm not mistaken don't you just unscrew the posts all the way and that center piece should just fall out. I would also just use the raw wire if all possible, unless the amp or receiver end is bi-wired then it will be too thick to fit in the LPA-1 post. I had to get bananas for the center and the mains. I have the same set up, and it's pretty quick to get everything connected, the only thing that sucks is the 705's 12V trigger only works on zone 2.
    F1nut Posts: 52,301
    Vonnie, just trying to keep things on track. :)
    MJW, these days there's not many, if any, OEM binding posts that unscrew all the way. Safety issues, ya know. The plastic plugs pop out easily enough. Bare wire oxidizes and is old school thinking, IMO. Soldered bananas are much better all around.
  • kwikrnu
    kwikrnu Posts: 32
    Atrocity wrote: »
    Emotiva has the lpa-1 instructions on line it shows how to do this.
    click here for the lpa-1 instructions online
    I just hooked mine up yesterday and it works nice.
  • Atrocity
    Atrocity Posts: 20
    This Zone 2 issue, is this something I need to be concerned about?
    kwikrnu wrote: »
    WOW! The amp is bigger than it look in pictures I saw on their site. Again, thanks for the instructions.
  • ben62670
    ben62670 Posts: 15,969
    I think you may need a little more room to breath there. You might also want to put some spacers under the amp for better air circulation, move it away from the wall, and move the remove the PrePro from the top of it.
    Ben
    Ben
  • kwikrnu
    kwikrnu Posts: 32
    ben62670 wrote: »
    Ben
    Why? I have run the amp for a few days now and it doesn't even get get warm. Do you know anything about the emotiva lpa-1?
    Read this link if you want to know more, "It runs cool so you can stack the LMC-1 processor or your existing processor or receiver directly on top."
  • kwikrnu
    kwikrnu Posts: 32
    Atrocity wrote: »
    Wait until you try to pick it up. It weighs more than my 5 y.o. daughter, I had to reinforce the shelf in my closet to accommodate it.
  • Davidpsalt
    Davidpsalt Posts: 24
    edited January 2008
    banana plugs
  • GregoryOrme
    GregoryOrme Posts: 25
    edited January 2009
    Atrocity wrote: »
    You don't need 20 separate cables, but as was stated, you will need 20 banana plugs for the five speakers because you will have a black and a red just like with any conventional setup. So, the center channel will have a black and a red going into the amp and a black and red connecting to the speaker for a total of four plugs to set up the one speaker. Same with the right side, the left side, and the two rears. Does that make sense?
    Gregory
    Power Amp: Emotiva XPA-3
    Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
    Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
    Surrounds: PolkAudio FXi A6
    Rear: Polk Audio RTi A3
    Sub: PolkAudio DSW Pro 500
  • seeclear
    seeclear Posts: 1,244
    edited January 2009
    This thread is over a year old, I hope he's got the darned thing hooked up already! :eek:
    Can you picture him sitting on the floor, a pile of nanners and a coil of wires heaped in front of him, saying "curse you Club Polk, you guys said this would be easy!!!" ;)
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
