The CJ/Krell show down on hold...
  • ben62670
    ben62670 Posts: 15,969
    edited December 2007
    It looks like I really did a number on the Krell due to my stupidity.
    Don't feel bad. Me stupid too.
    Limited edition GFA-585.
    3000 made.
    Two spades...SDA's
    2 transistor no longer made. $5 each. Poof.
    You can't just buy a transistor, and be done with it. You need to have 5 matching transistors that match the other set(push/pull). I blew one on each channel. 20 transistors in all.
    You can't just buy 20 transistors. They have to be beta matched carefully. I need to purchase 25 each 50 total $5 each(2 flavors) to get 20 transistors. If I buy any less I will be risking not getting a good match in a set (25 is a full rail from the same batch). The good thing is I will have extra transistors left over for building custom amps:)
    Ben
  • pearsall001
    pearsall001 Posts: 5,257
    Ricardo wrote: »
    I am offended because you are delaying my chance to win an aftermarket power cord.
    So sorry!!! :D
  • madmax
    madmax Posts: 12,434
    dorokusai wrote: »
    I blew up a tube amp while setting bias on the last of 8 tubes. I was told later that I may....MAY have been drinking at the time. Not only did the amp need to be repaired but I had to buy a whole new octet since they were original tubes. Oh well, lesson learned.
    Waaaaaaaaaaa
    madmax
    Vinyl, the final frontier...
  • hearingimpared
    hearingimpared Posts: 21,136
    madmax wrote: »
    That would have never happened with a tube amp... :)
    Actually, I'm pretty surprised the problem is allowed to go unprotected by krell. You should be able to short those without causing damage. Hope it all turns out ok.
    madmax
    Neither the external or internal fuses blew . . . it just was that fast.
  • hearingimpared
    BTW thank God for the ignore function!!!
