New cabinets for my 10As
mavz
Picked up a pair of 10As at the local Goodwill for the rediculous price of $35/pair. The cabinets are in very poor condition but the drivers/crossover seem to be OK. As a perpetual audio experimenter I plan on rebuilding the cabinets and was thinking of an MTM layout with the passive woofer fired sideways. I would maintain the same internal volume, but make the front of the cabinet just wide enough to support the mid/woofers. Looking for suggestions/thoughts on the concept and or layout of the drivers.
Post edited by mavz on
Suggestion, re-build the 10's as they were intended, dont change the cabinet.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I concur. That will totally change the voicing of the speaker. But, it might be a fun project to see what happens especially if you're making them out of MDF or something first to see what they sound like. I would try it in inexpensive form before I went all out on something fancy that doesn't cut the mustard. Who knows...it might work ok.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
How bad are the cabs? Why don't you just try to restore them?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'm curious about the MTM design as well, with a back firing passive. Of course I'd keep the original cabinets. Just use puddy and flexible veneer. I did that some 20+ years ago using flexible Oak veneer. Turned out pretty good. Definitely better looking than the vinyl rosewood.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
If you want the MTM design, just make a new pair of speakers. It's a good project. But keep the Monitors; they are classic speakers that can be brought back to life.
