Hi, my name is Mike, I'm a speaker hoard...
Face
Here's what I managed to pick up in the last month off my local Craigslist.
From L to R.
Monitor 7C, Monitor 10, and Monitor 7.
After listening to all three, I'm torn between the 7 and 7C. I upgraded the caps and resistors in the 7C and am starting to prefer it over the 7, even though the 7 has the infamous Peerless tweets. I also have a pair of RD0-194's ready to go in the 7c's. After that, it'll probably be no contest.
As for the M10's, I was taken back by how much I don't like them. I don't know if it's my room or placement, but they're very boomy compared to the 7 and 7C. I usually prefer large speakers due to better bass response in my difficult room, but I'm disappointed in these. Would a crossover upgrade help, or are they inherently boomy?
I also had a chance to pick up a pair of SDA2's and Acoustic Research 9LS's. Due to a lack of space, no way of getting them home, and a bad back and shoulder, I had to pass. This is my second time I missed out on a pair of SDA's. I'll own a pair eventually, but I guess it'll have to wait.
From L to R.
Post edited by Face on
Put some new caps on the Peerless 7's; I think you will like them better._________________________________________________
I wouldn't call the M10s "boomy" (at least by my standards), but they are quite bassy in my room as well. I would usually run with the bass trim knob at about 9:30 position, so knocking quite a bit off.
It might be worth checking to make sure all the padding that is supposed to be in there is in place. -
I love the boom of the M10's. Its their most endearing characteristic.
A fellow addict...
ya man !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Looking good Mike
I confess..addict here as well...I would need more then one room and a dolly to assemble all I have gotton off of craigslist in the past few months. Its been a few crazy months on craigslist for me....so damn addictive
The first rule of Fight Club is you don't talk about Fight Club -
Right on Bro!
Mike,very nice lookin collection you got going there.
Note - monitor 10's sound much much better on stands. I would not even run them just sitting on the floor. Could that be your issue?Mains.............Polk LSi15 (Cherry)
Hi, my name is Mike, I'm a speaker ho...
There, fixed it for you.
President of Club Polk -
Hey Mike, you live in Long Island?
I'm pretty sure EDSAVINON (may be spelled wrong) has a pair of SRS 2's for sale and he lives in the bronx.
Sal
I have a few sda speakers for sale.
I can deliver them if interested.
I have the sda crs,crs+,1c,srs 2, available.
Let me know if you want to add some sda's to your collection.
I have too many polk speakers stored and need to make space.
Thanks sal.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Hey, now you know where you can get a pickup truck for hire, right?
I'd like to really get to hear those Tannoys/Mc some day, too.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Hi, my name is Mike, I'm a speaker ho...There, fixed it for you.
Oooooooom Calling Rev Al, Calling Rev Jesse!!! -
hearingimpared wrote: »Oooooooom Calling Rev Al, Calling Rev Jesse!!!
They wouldnt care...Its not like he called them nappy headed
Wow you have a nice group of speakers there. And alomost all the tweeters Polk made back then.
The Mon10's don't like to be near a back wall. And if you are using them in the area you took the picture in they will be boomy. The narrowing of the walls creates a big bottom end in even small speakers.
I miss my 10's. I had both series you have there. The 7's were great a good all round speaker. Go get some SDA's from ESAVINON.
Go get -
That's the plan when I'm done with my Tannoy crossovers.Put some new caps on the Peerless 7's; I think you will like them better.
I don't use tone controls.I wouldn't call the M10s "boomy" (at least by my standards), but they are quite bassy in my room as well. I would usually run with the bass trim knob at about 9:30 position, so knocking quite a bit off.
When I opened them to check out the crossovers, all the wadding appeared to be in place.
I knew you'd respond.Looking good Mike
That's possible. I moved them around a couple more times and they sound a little better. While writing this, I just remembered I have a set of stands buried in the basement that would work.Note - monitor 10's sound much much better on stands. I would not even run them just sitting on the floor. Could that be your issue?
You said you wouldn't tell anyone.There, fixed it for you.
They're being used in a different room. They're about 2' from the side walls and 4' from the back wall.The Mon10's don't like to be near a back wall. And if you are using them in the area you took the picture in they will be boomy. The narrowing of the walls creates a big bottom end in even small speakers.
ESAVINON, I'm about to send you a PM."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I forgot to mention the crs,crs+ come with the original stands.SRT For Life; SDA Forever!
Yeah, definitely put the 10s on stands - they were designed to be on them, so I would imagine connected directly the floor they would indeed sound very bassy.
