Biwiring RT3000s?
mhartman29
Does anyone have any experience biwiring these speakers? I am about to order some new speaker wire, and I'm not sure if I should try to biwire mine or not.
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Post edited by mhartman29 on
Mine are bi-wired, not that you can really tell from the sound.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
So, it isn't worth the extra expense to biwire them?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Ultra speaker cables -
In my opnion there was no real difference in sound from a good set of wires.
Originally I went from cheapo low gauge wires to bi-wires and there was a big difference but when I switched them out to try heavy 10g wires I did not noticed a diff.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
iif there is a set of biwires used for a good price, go for it. in my experience, biwiring is not much of a difference. improving the jumper itself might be.
other people might have differing opinions. this has been the subject of very heated debate in the pastLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
That is true, if you can get bi-wires for around the same price as others then buy them.
I would not avoid them but I would not spend extra money for them.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
