Biwiring RT3000s?
mhartman29
mhartman29 Posts: 257
Does anyone have any experience biwiring these speakers? I am about to order some new speaker wire, and I'm not sure if I should try to biwire mine or not.
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • Skynut
    Skynut Posts: 2,967
    edited December 2007
    Mine are bi-wired, not that you can really tell from the sound.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • mhartman29
    So, it isn't worth the extra expense to biwire them?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • Skynut
    Skynut Posts: 2,967
    In my opnion there was no real difference in sound from a good set of wires.
    Originally I went from cheapo low gauge wires to bi-wires and there was a big difference but when I switched them out to try heavy 10g wires I did not noticed a diff.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • ohskigod
    ohskigod Posts: 6,505
    iif there is a set of biwires used for a good price, go for it. in my experience, biwiring is not much of a difference. improving the jumper itself might be.
    other people might have differing opinions. this has been the subject of very heated debate in the past
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Skynut
    Skynut Posts: 2,967
    That is true, if you can get bi-wires for around the same price as others then buy them.
    I would not avoid them but I would not spend extra money for them.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
