Ohm ?
ben62670
What is 0.637 K ohms in ohms.
I used an active XO calculator, and it gave me that number. What resistor should I be looking for?
Thanks Ben
Thanks Ben
Ben
Ben
Post edited by ben62670 on
Is it 637m ohms?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
637 ohms, Example, 1000 ohms = 1k ohm.
Thanks Ben
The K would make you move the decimal point over to the right three places, therefore you get 637 ohms.
When I figure in the K of a number I add three zero's to the right of the number but with the decimal point it is as above.
Whoops Sorry Russ I just saw that your post. -
Go to bed Joe:)
I think you're right I'm seeing double and I have drunk anything but water all night!!!
Google will actually do conversions like this for you. For example, for your question, you'd type ".637 Kiloohm to ohm"
It'll convert all sorts of crazy stuff. I use it all the time to avoid stupid errors. -
Thanks guys. I was dead tired trying to do calculations. I knew the decimal point had to go 3 places. I just didn't remember which way:oPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
