Ohm ?
ben62670
ben62670 Posts: 15,969
edited December 2007 in DIY, Mods & Tweaks
What is 0.637 K ohms in ohms.
I used an active XO calculator, and it gave me that number. What resistor should I be looking for?
Thanks Ben
Ben
Post edited by ben62670 on
  • ben62670
    Is it 637m ohms?
    Ben
  • lightman1
    lightman1 Posts: 10,800
    637 ohms, Example, 1000 ohms = 1k ohm.
  • hearingimpared
    hearingimpared Posts: 21,136
    ben62670 wrote: »
    Thanks Ben
    The K would make you move the decimal point over to the right three places, therefore you get 637 ohms.
    When I figure in the K of a number I add three zero's to the right of the number but with the decimal point it is as above.
    Whoops Sorry Russ I just saw that your post.
  • lightman1
    Go to bed Joe:)
  • hearingimpared
    I think you're right I'm seeing double and I have drunk anything but water all night!!!
  • nms
    nms Posts: 671
    Google will actually do conversions like this for you. For example, for your question, you'd type ".637 Kiloohm to ohm"
    It'll convert all sorts of crazy stuff. I use it all the time to avoid stupid errors.
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • ben62670
    Thanks guys. I was dead tired trying to do calculations. I knew the decimal point had to go 3 places. I just didn't remember which way:o
    Ben
