Level 2 mod...worth it ?
beardog03
I`m thinking of getting a level 1 mod on the Jolida CDP, and was wondering if the level 2 is worth the extra $$
Any thoughts ?
Any thoughts ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
- and I've seen the way you go through gear.
QUOTE]
:D:D:D
That`s why I ask !!
I`m looking at a Cary 306 SCAD . or 303 / 300 CDP
Just not sure about the $$
I still have $ problems to deal with, but I`m an audio addict !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Level 1 is waste of money. I have a level 1 mod and a total stock. I can't tell the difference, maybe my ear ...... IMHO, it is either all out (level 3 mod) or leave as stock. Sean is right, mods depreciate a lot quicker, if you may sell it within the next 12 months, think twice. You probably won't get half of what you pay for the mods. You may want to consider a upscale outboard DAC, just a thought.
-fredv- -
Level 1 mod
-4 sheets of SOUNDCOAT dampening material are applied to the internal chassis
-4 EAR compliant Sorbothane isolation feet are put on the bottom.
-We add 1 pr. of VAMPIRE RCA jacks (OFC Copper body, gold-plated)
-We replace the internal wiring with 2 ft of DH LABS pure silver, Teflon dielectric, output wire.
-8 Ultra-fast, soft recovery HEXFRED and FRED diodes are used in the power supply
-7 BLACK GATE Standard, N and C grade electrolytic capacitors are added around the coupling caps and power supply.
-14 AUDIO NOTE Tantalum 1/2 watt resistors are used in the signal path-8 MULTICAP PPMFX grade, metallized polypropylene capacitors are used in the signal path.
-We replace the stock tubes with a pair of Electro Harmonix 12AX7 tubes which are a dramatic upgrade from the stock Chinese tubes in the stock unit.
-TRT Wonder Solder is used throughout.
-There are Approximately 4 hours Labor involved in the mod.
The following is a description of the Level-2 mod:
-7 BLACK GATE Standard, N and C grade electrolytic capacitors around the coupling caps and power supply
-4 BLACK GATE 150uf 350V VK grade electrolytic capacitors used for the high voltage power supply reservoir*
-AUDIO NOTE Tantalum 1/2 watt resistors - signal path
-4 MULTICAP PPMFX grade, metallized polypropylene capacitors used in the signal path
-4 MULTICAP PPFXS grade, polypropylene film and tin foil coupling capacitors*
-4 REL-CAP TFT grade, 0.01uf Teflon film and tin foil, bypass capacitors for the main coupling caps*
-4 sheets of SOUNDCOAT dampening material (applied to internal chassis)
-1 pr. VAMPIRE RCA jacks (OFC Copper body, gold-plated)
-2 ft. DH LABS pure silver, Teflon dielectric, output wire
-8 Ultra-fast, soft recovery HEXFRED and FRED diodes - power supply
-One pair of EH Gold Pin tubes*
-Approximate 6 hours of Installation Labor*
Note: The items with an asterik (*) are upgrades over the Level-1 mod.
I'm not so sure the Level 2 mod is worth another $550.00. Also note that they say they use 4 BLACK GATE 150uf 350V VK grade caps, but in reality there are only 3.Political Correctness'.........defined
President of Club Polk -
THat`s what I read into it...not much difference in the level 2 mod..
Fred, where do you get the level 3 mod at?
What do you think of the Cary cdp that I mentioned ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I don't see the Level 3 mod any longer. Basically, it added a new clock and clock power supply, which they still show. It costs $480.00 more for that.
I have little doubt that the 306 SACD player is far better. Of course, it costs over double that of a fully modded Jolida.Political Correctness'.........defined
For some reasons, my memory told me there was a level 3, I couldn't remember it was real or not, I couldn't find it any more , sorry. I think the imagine L3 had the master clock replaced.
I didn't audition the Cary cdp, so I don't have first hand comment. From what I have read, it has typical Cary sonic signature (i.e. SQ most people expect from Cary) but QC seemed to be not. But then it is a very small sample, I wouldn't put much weight on it.
-fredv- -
It is really funny, Each time I posted my reply, I saw a new reply from Jesse :-) How are you doing, my friend!!
-fredv- -
I'm great Fred. I trust that you are too. Give my best to your lovely family.
Any new pieces in the house?Political Correctness'.........defined
i second fredv on the outboard dac.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
even on the Jolida ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
if you mean outboard dac on the jolida, yes.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
really ?
I thought that being a tube CDP, it would defeat the purpose..
I have wanted to try a DAC , especialy aftr reading about them here on the forum
I was looking at a MF DAC....kinda spendy, but I understand that MF is top notch
Musical fidelity A3.24 dac
any thoughts ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
you can always get a tube dac. i have the ack dack 1.2e which is a battery powered dac. i own the onix xcd-88 cd player which i could have thrown extra money at with upgrades but then if you are going to spend all that extra cash on upgrades why not start out with more expensive/better cd player. the ack has made a hugh difference in sound quality..Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I`m selling the The AH!, and that will mos likely be the funds to get a DAC, as my $ problems will have to work themselves out..
Hi, my name is Robert...and I`m an audio addict......Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
HI ROBERT.
Mods are really a double edged sword. Sometimes they're worth it & sometimes not. You really don't know till you send the piece out to get the work done & hopefully you hear a difference in the sound. Also if you're the type who doesn't hold on to gear for any length of time, selling a modded piece is a hugh money lose. Mods just don't hold any value."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Hi Jesse,I'm great Fred. I trust that you are too. Give my best to your lovely family.
We're doing well. It will continue to be the case if I still have a job after the coming Friday
Regarding to new pieces, nothing from commercial if you don't count new tubes :-) I built a mini version of Allen Wright's FVP preamp. It is still work in progress and has replaced the Transcendant Sound Ground Grid in my main rack!!
-fredv- -
You talk like that's a bad thing.:) I can think of lots of worse things to be addicted too, many of which leave you with nothing, or nothing useful, to show for your time and money.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I was lucky enough to hear an Onix CD-5 stock and the level 1 mod. I was quite impressed by the improvement. My Jolida cdp is a mod and I think it's a killer unit (not done by Underwood). The key is how long you're going to hang on to the unit. Long term, go for a level 1. Short term, just get an outboard DAC.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
I lik ethe unit, I just want to get all the potential out of it..
If it is what it is said to be after the mods, I would keep it for many moons.....if not I would sell and move to the next up the ladderCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I have the HRAM stage 3+ JD100A and it is a Keeper
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
