Avia DVD
dbournival
I used the test tones on my system to setup levels with a SPL meter. My system 1 sounded good, system 2 very weak in bass (Onkyo issue, i'm told).
I then used the THX setup on Monsters inc, my sound levels were pretty far off. It sounded better afterward, but the THX says it is not to be used for setting speaker levels. I going to get either the Avia setup disc or the Sound and Vision one. Does anyone have experience with either? Is the Avia worth the extra money?
Post edited by dbournival on
i used avia and i will give a defininte thumbs up. well worth the money..the video stuff on there is good tooSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
I have the S&V disc and it is also VERY good. It includes calibration for both DD and DTS 6.1, contains demos for both, and is fairly comprehensive in scope. All in all, a great buy, I think. For only $18 at Best Buy, you can't go wrong.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
I ordered and used the AVIA disc and was pleased with it. As to the s&v disc I looked at it at my local Best Buy and it was $50 and came with 6 mo. online assistence with speaker placement. I'm sure they will both do a good job I just chose AVIA because that's what the hi-fedelty store used for their set-ups.
Good luck
Dave
