Cable burn-in: truth or myth
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited December 2007
    nms,
    well we all have to deal with what we have for rooms. Glad to see you are joining the fray. Welcome.
    RT1
  • Ricardo
    Ricardo Posts: 10,636
    hypertone wrote: »
    Would you mind scraping off that white buildup and sending it to me? ;)
    No, I would not scrap it, but if you NEED it I can send it to you.
    SOPA
  • vonnie123
    vonnie123 Posts: 326
  • shack
    shack Posts: 11,154
    vonnie123 wrote:
    Here's an interesting concept.
    http://www.hagtech.com/frybaby.html
    Nothing new...they've been around for awhile. Here is the "Cable Cooker":
    http://www.enjoythemusic.com/magazine/equipment/0404/audioharma.htm
  • wingnut4772
    wingnut4772 Posts: 7,519
    I have a very difficult time believing cable burn in. Electronics.....um..maybe. Speakers for sure but cables??? I can't buy into it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • shack
    shack Posts: 11,154
    We just made it all up...
  • Face
    Face Posts: 14,340
    shack wrote: »
    You're mean. :D
    I'm still on the fence. I'm not denying it, but I haven't noticed it yet either.
  • Ferres
    Ferres Posts: 310
    The possibility of a placebo effect is a bit high on this one in my opinion.:confused:
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • beardog03
    beardog03 Posts: 5,550
    Wha...wha..wwhat ...??!!
    Et Tu Wing ?
    spaeker, and electronics, but not cables ?
    oh, yes....cables too......
    YMMV of course
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • reeltrouble1
    All of the MIT cables I have purchased have sounded better after they were used for a while. Just little things with the bass and treble on certain tracks. Anyway I have heard enough to believe the burn-in for cables is not a myth by any means.
    RT1
  • wout
    wout Posts: 64
    What happens in the cables is that the molecules align themselves with the flow of the electrons that pass through. So over time the more those molecules align with the flow the better the flow. If you were to reverse your cables after playing them for a while the flow would be hampered by these molecules that are aligned the wrong way. So keep your cables aligned properly and yes of course you have to burn in your cables, just like your speakers and your equipment as well. Also, never ever let your system sit idle for long periods of time because you will have to burn it in all over again. Just like you can't let a car sit in the garage over the whole winter and expect it to just start up. If you just bought that there is a bridge for sale, then again you are entitled to believe whatever you want. This is free country (was).
    Speakers: LSi15 front
    Integrated amplifier: NAD 320BEE
    Furman PL Plus Series II (line conditioner)
    HD DVD A35 Toshiba (Sloooooowwwww to start)
    Oppo HD981 (Nice unit)
  • ben62670
    ben62670 Posts: 15,969
    To the extent of having to burn in cables depends a lot on cable design, and components used. If you have a real high res system you will notice burn in more prevalent. Of the cables that I have built the stranded cables take longer to burn in than the solid ones. I use solid silver, or silver plated cooper with Teflon for all cables. My braided solid conductor IC's don't take long to see an improvement. The stranded Star Quad types take a long time to burn in.
    Ben
  • WilliamM2
    WilliamM2 Posts: 4,807
  • jwhitakr
    jwhitakr Posts: 568
    wout wrote: »
    ... If you just bought that there is a bridge for sale, then again you are entitled to believe whatever you want. This is free country (was).
    WilliamM2 wrote: »
    That is the most ridiculous thing I have ever read. You do realise that the audio signal is AC right? The signal flows BOTH directions. They constantly change direction on their own.
    While wout's sentence structure wasn't the best, at the end of his paragraph he did point out that he had a bridge for sale. I believe he was using that to point out his sarcasm.
    :rolleyes:
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • WilliamM2
    jwhitakr wrote: »
    :rolleyes:
    You're right, I had to read that sentence a couple of times to make sense of it. Sorry.
  • reeltrouble1
    who care's?????
    Ed Zachery.
    RT1
    F1nut Posts: 51,761
    My cables can beat up your cables and that's a fact, Jack. :D
  • danger boy
    danger boy Posts: 15,722
    PolkFest 2012, who's going>?
  • ben62670
    danger boy wrote: »
    What are you trying to say:D
    Love it!
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    Cable burn-in, just like anything that eletrons flow through to reproduce sound need to burn-in. Everything from the dielectric to solder needs to get with the flow.
    If you don't believe it, bully for you, but if you have any kind of high resolution gear, you will hear a big change once the cables have burned in.
  • janmike
    janmike Posts: 6,146
    It really does depend on the cables and gear. I have heard subtle differences on cables from Signal and quite noticeable differences on MIT.
    Michael ;)
    NORTH of 60°
  • Sevenpointone
    Sevenpointone Posts: 12
    Myth- in 50 hours of 200 watt amp usage, your amp changes more than any quality speaker wire.
    7.1
