Cable burn-in: truth or myth
nms
Hi guys.
To make this brief: Vintage Monitor 10Bs pushed by Carver HR-752. Right channel using 20 year old speaker wire of no particular note. Left channel using Monster 16 Ga speaker brand spanking new. Both lengths about the same, both gauges about the same. Right channel has clearer highs - what gives?
Things I've ruled out by experimentation:
- The receiver. When wires are swapped @ receiver the left speaker highs still sound stuffy.
- The speaker. Moved the speakers so right became left and left became right. The left speaker highs still sounded stuffy. This seems to rule out the tweeters being at fault.
That leaves me with the speaker wire. So my question is, is speaker wire "burn-in" real, and the monster cable will sound better after some hours are put on it?
Thanks,
nms
Thanks,
nms
Post edited by nms on
The test is flawed since they're two different cables."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Face, that's the point. :-) Besides, I'm not purposefully running a test, I just noticed one speaker sounded better and went from there.
One cable is brand new, and is supposedly a high end speaker cable. The other one is an old, used off-brand cable (better than lamp cord wire, but not specifically an audio cable, either).
The old one, despite its lower quality, sounds better in the highs than the monster cable. I have a hard time believing that this old cable is better than the monster. The only thing I can think of is that the old cable has been used to drive speakers for a while, while the monster cable is brand new, so it needs to be "burnt it".
The question is 1) Is burn-in real? 2) If so, how long does it take to burn in a cable? 3) If not, why the hell does the monster sound worse?
Thanks -
Face has a point...
one cable is new , one old...
but yes, I do believe in cable burn in
It takes a while for any cable to "settle" in
Others would disagree
they`re wrong
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
That's the other flaw, Monster is not high end.One cable is brand new, and is supposedly a high end speaker cable. The other one is an old, used off-brand cable (better than lamp cord wire, but not specifically an audio cable, either).
<SNIP>
All Monster cares about is a Monster profit."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I'm inclined to agree with you. I bought Monster because I wanted 16 Ga, and BB only had monster in that size.
Another question: does a non-burned in cable normally affect the highs, like I am hearing, or some other part of the frequency spectrum? -
Why don't you get two speaker wires of the same type and length, install them and get what you want to achieve? That being equal sound out of both speakers.
To answer your other question, yes for some and myth for others. Does it really matter if you don't or do hear it? If a bear **** in the woods, does it make a noise? Who cares? That's my point.
Get new [same] speaker wire and tell us after about 50 hours whether or not you hear any sonic change and then YOU will know.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I'm a cheap sunuva ****, that's why ;-). 20' feet of monster was all that I was willing to pay for, and initially I thought it would be enough to wire both speakers. HOWEVER, when I got back and actually measured it out, I would need closer to 30'. I had an old piece of serviceable wire from the speakers' previous installation, and decided to use that instead of going to the trouble to return the 20' spool and buy a 30' one. I'm glad I did, as I never would have heard the difference between "new" and "burnt-in" wire otherwise. It's been educational.
I posted this because I wanted to make sure the sonic difference in the top end I was hearing was in fact the new wire, and not something wrong with the speakers or receiver. Then, when a few members responded that wire burn-in was a real phenomenon, I wanted to know how long it takes to properly burn-in a wire. You seem to have answered this with your "50 hours" comment. For that, I thank you.
Now, since my questions seem to be annoying to you and Face for some reason, I'll stop posting and enjoy my new stereo, which is all I wanted in the first place. I unsarcastically thank you all for your help, even if it did feel like I was pulling teeth :-) -
Rather than rehash all over again....here is a thread regarding this exact topic from a couple of years ago. All the ususal suspects chimed in. I said enough then so I won't repeat anything other than...based my experience cable burn in exists.
http://www.polkaudio.com/forums/showthread.php?t=27534"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
you may also be experiencing this because the older cable may have corrosion on the ends or somewhere in between..
Stick around and enjoy the forum....your not annoying anybody...and f em if ya are..!
but as shack said, do a search and you will find many threads / opinions on this subjectCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Are you saying that you can hear a difference in sound, and that you are absolutely positive that the culprit is the speaker wires?????
Do you want a million dollars???:eek::D:D_________________________________________________
Cables are a crock . . . I just give the Signal Cable Guy my money for fun because I have tons of it. Not to mention, the weight and gauge of these Magic Power Cords would make great nunchucks in case those ninjas come back and try to take my speakers again.
I'm saying that I am hearing a noticeable difference in tweeter behavior/sonic output between the L and R speakers, with the L one sounding "stuffier" and worse.
All of the experiments I have done (listed in my first post) seem to point to the cable being the culprit. I do not think this is mental, because I expected to find the exact opposite results. Since I believe that the Monster cable is of higher quality, that leaves me with burn-in as the likely culprit for the poorer sound quality.
So no, I am not absolutely positive that what I am hearing is cable burn-in, but I believe that it is the most likely reason for a PALPABLE sonic difference.
I am no audiophile, but I have good ears and I trust them (can still hear 19 KHz TV buzz at ~20 yrs old).
The best test now is to wait several weeks of intensive playback and then perform my left channel / right channel test again with a selection I am very familiar with. If the difference has disappeared, I will conclude it is cable burn-in and that it does exist. If the difference is still noticeable, I will perform the tests listed in my first post again, and then try to fix whatever is broken.
And yes, I would love a million dollars. Who's giving it out?
BEARDOG:
I am having trouble picturing how corrosion would make the older cable sound better. Thoughts? -
Maybe i'm missing something here, but you listed in your tests that you:
1) swapped cables at the receiver and,
2) swapped speakers
If you swapped cables at the receiver and the problem remained in the left channel doesn't that rule out both the speaker and the cable, and point directly to the receiver?
I mean, if the LEFT channel on the receiver was using the new Monster cable and the RIGHT channel was using the old cable and you switched at the receiver then the LEFT channel would then be using the old cable and the RIGHT would be using the Monster cable, with each hooked up to their original speaker. If the cable or the speaker were the culprit, wouldn't the problem have jumped from the left channel to the right channel when you made the swap?Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Just a lame attempt to stir the pot on cables discussions; I don't doubt you hear differences.
On the million dollars:
http://www.polkaudio.com/forums/showthread.php?t=58314&highlight=million_________________________________________________
I don't understand what the problem is. You said your cheap and the cheap cable sounds better than the Monster cable. So do you want us to talk you out of taking the Monster cable back? I'd add the old cable to the other speaker and move on.
tcrossma:
It's confusing to explain, I'm trying to think of a good way of explaining what I did. When I swapped cables at the receiver, the L channel output went to the speaker on the right, and vice versa. The cables stayed hooked to the same speakers, and the problem stayed on the L speaker (not the L channel) with the Monster cable. In the second test, the receiver outputs were returned to normal and the speakers were physically swapped, but the cables stayed in the same place. In this test, the new L speaker had the same problem as the old L speaker. The speakers were put back as before and the problem persisted on the left. Ergo, the Monster cable, which always drove the speaker on the left, is the problem. I hope this explains it better.
Ricardo:
Forgive me for not taking your comments as a pot-stirring attempt. Tone is difficult to read through text.
wallstreet:I'd add the old cable to the other speaker and move on.
The problem with this suggestion is simple: I'm out of old cable
:rolleyes: -
In your case, your right ear hears better than your left.
BEARDOG:
I meant that the OLDER cables would have possible corrosion, hence the unclean (muddy)sound
I could be wrong...
It happened once before....;)Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
OK, I can deal with that.I'm a cheap sunuva ****, that's why.
This, I can not. I answered your question and offered a solution, Face just gave you the truth.Now, since my questions seem to be annoying to you and Face for some reason, I'll stop posting and enjoy my new stereo, which is all I wanted in the first place. I unsarcastically thank you all for your help, even if it did feel like I was pulling teeth :-)
How long,and at what temperature should I leave my cables in the oven
JC approves....he told me so. (F-1 nut) -
Hi guys.
Thanks,
nms
I would lean towards the room giving you some problems, more reflective on one side and more absorbing on the other. As I read it it is always the left no matter what you do, correct? -
nms...May I suggest you return the monster cable? Get yourself some good quality speaker cable here:
Will BB take back cable that's been cut to length?? I assumed not initially.
Possible. I will do another experiment later today when I won't wake the neighbors. However, The high end difference is noticeable from a listening position, as well as right up against the speaker where environmental variables do not have much influence.I would lean towards the room giving you some problems, more reflective on one side and more absorbing on the other. As I read it it is always the left no matter what you do, correct?
Thanks -
Well I owe you guys an apology for the wild goose chase: it's the tweeter in the left speaker. I feel pretty stupid now.
If it's a Peerless tweeter, I can send you one.....not new, but it works. Has some "magic dust" on it, but it doesn't seem to affect the sound.PM me your addy and I will ship it sometime next week.
Hocus PocusSDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
If you get the tweeter from Ricardo,make sure that it has been properly "licked",before installation.:)JC approves....he told me so. (F-1 nut)
Would you mind scraping off that white buildup and sending it to me?
Depending on your room you can get a situation where moving your head a few inches either way can cause one speaker to seem louder than the other randomly. Just something to pay attention to.Vinyl, the final frontier...
Thanks, I'm pretty careful about listener orientation - otherwise Carver's "Sonic Holography" doesn't work!
(Not that it works incredibly well in my small room anyway...)
After being driven hard the tweeter seems noticeably more "stuffy" and "crackly", so I'm pretty sure it's the tweeter at this point.
But yeah, my speaker setup is far from ideal: they're too close together, and on the outside of each speaker is a cubby hole that further attenuates the already fantastic bass - yikes! In front and to the outside of each is a short wall, so I get some weird reflections from there. I've toed the speakers in to try to get rid of some of that... Oh, and they're too close to the wall behind them. Even so, they sound fantastic - I definitely have more than enough power to ruin my eardrums and shake the building, if I ever feel so inclined, and they'll continue to sound good as the walls crumble around them!
