Bi-wiring
I just got a pair of RTi10s that I picked up in the post-Thanksgiving sales, along with a CSi3 and two FXi3 (those are on order). They're hooked up to my Yamaha HTR5740 and sound great. It seems to me that the RTi10s are capable of being bi-wired, so I'm wondering 1) how much of a difference will this make in the sound for both music and movies and 2) as my Yamaha is a 6.1 system, will it work if I bi-wire it to both the A and B connectors? Any advice/help is much appreciated.
Post edited by bubbalou on
Welcome!
    edited November 2007
    Unless you use seperate amplification (external amp ) you will most likely not hear any difference...
    It`s doable, but a waiste of time..IMO
    I will let the other chime in though
    Welcome to CP !
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    bubba, beardog is right... biwiring is a waste of time. there isn't much of anything to gain. i gave it up years ago after going back and forth with my system and trying bi wiring. i settled for non bi wiring.. and it sounded just the same to me.
    PolkFest 2012, who's going>?
    never noticed a difference in bi wiring unless running tons of power, what does make a big difference however is bi-amping the rti10s i did this off my onkyo sr604 and noticed a huge difference. if you have extra channels that you are not using try it out. use a dsp setting of 5 channel stereo to have both halves of the speakers have full range output
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
    You would be better off buying a good pair of wires than a pair of bi-wires
    Ben
    Thanks for all the good advice. They sound amazing already.
    I'm pleased to see that most here agree that "bi-wiring" should be called "buy-wiring". ;) I believe the quote originated with Tom Nousaine.
    As some have noted, bi-amplification is a different beast and can be quite effective.
    "You can tell by the kindness of a dog how a human should be." Don Van Vliet
    If you have speakers that are bi-wireable but do not have jumpers can you just make them out of speaker wire?Is it best to plug the speaker cables into the high or low frequency jacks?
    Thanks to encouragement from Peffy's post: I finally gave bi-amping a try (I had a similar situation - Onkyo TXR705 trying to drive incredibly hungry RTi10's) Within seconds of powering on, it was clear that It wasn't going to require serious analysis... the difference was night and day: violins sang rather than squawked, I could finally hear the basses play instead of a muddy low rumble.
    Although purchasing an Amp might produce the same (or better) results - and, I'll likely go that route in the future, for now I don't HAVE to come up with big bucks, and worse yet, find a location for the amp. I'd even considered returning the 10's - now I absolute adore them.
    So the moral of the story.. in specific situations bi-amping can be bliss.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
    Don't waist your money. You won't hear a difference.
    TalkenRain wrote: »
    Well now,that all depends on your gear my friend.
Welcome!
Welcome!
