Bi-wiring
bubbalou
bubbalou Posts: 3
I just got a pair of RTi10s that I picked up in the post-Thanksgiving sales, along with a CSi3 and two FXi3 (those are on order). They're hooked up to my Yamaha HTR5740 and sound great. It seems to me that the RTi10s are capable of being bi-wired, so I'm wondering 1) how much of a difference will this make in the sound for both music and movies and 2) as my Yamaha is a 6.1 system, will it work if I bi-wire it to both the A and B connectors? Any advice/help is much appreciated.
  • beardog03
    beardog03 Posts: 5,550
    edited November 2007
    Unless you use seperate amplification (external amp ) you will most likely not hear any difference...
    It`s doable, but a waiste of time..IMO
    I will let the other chime in though
    Welcome to CP !
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • danger boy
    danger boy Posts: 15,722
    bubba, beardog is right... biwiring is a waste of time. there isn't much of anything to gain. i gave it up years ago after going back and forth with my system and trying bi wiring. i settled for non bi wiring.. and it sounded just the same to me.
    PolkFest 2012, who's going>?
  • peffy03
    peffy03 Posts: 50
    never noticed a difference in bi wiring unless running tons of power, what does make a big difference however is bi-amping the rti10s i did this off my onkyo sr604 and noticed a huge difference. if you have extra channels that you are not using try it out. use a dsp setting of 5 channel stereo to have both halves of the speakers have full range output
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • ben62670
    ben62670 Posts: 15,969
    You would be better off buying a good pair of wires than a pair of bi-wires
    Ben
  • bubbalou
    bubbalou Posts: 3
    Thanks for all the good advice. They sound amazing already.
  • bluzrip
    bluzrip Posts: 93
    I'm pleased to see that most here agree that "bi-wiring" should be called "buy-wiring". ;) I believe the quote originated with Tom Nousaine.
    As some have noted, bi-amplification is a different beast and can be quite effective.
    "You can tell by the kindness of a dog how a human should be." Don Van Vliet
  • 928man
    928man Posts: 71
    If you have speakers that are bi-wireable but do not have jumpers can you just make them out of speaker wire?Is it best to plug the speaker cables into the high or low frequency jacks?
  • xandra
    xandra Posts: 291
    Thanks to encouragement from Peffy's post: I finally gave bi-amping a try (I had a similar situation - Onkyo TXR705 trying to drive incredibly hungry RTi10's) Within seconds of powering on, it was clear that It wasn't going to require serious analysis... the difference was night and day: violins sang rather than squawked, I could finally hear the basses play instead of a muddy low rumble.
    Although purchasing an Amp might produce the same (or better) results - and, I'll likely go that route in the future, for now I don't HAVE to come up with big bucks, and worse yet, find a location for the amp. I'd even considered returning the 10's - now I absolute adore them.
    So the moral of the story.. in specific situations bi-amping can be bliss.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • TalkenRain
    TalkenRain Posts: 13
    Don't waist your money. You won't hear a difference.
    TalkenRain wrote: »
    Well now,that all depends on your gear my friend.
