further bi-wiring questions
928man
928man Posts: 71
If you have speakers that are bi-wireable but do not have jumpers can you make your own or is it better to buy aftermarket? Which input should you plug cables into (high or low) vs which ones to "jump" to?
Post edited by 928man on
  • beardog03
    beardog03 Posts: 5,550
    edited November 2007
    Yes you can make them very easily...and it is IMPO better than the jumpers that come with the speaks...YMMV
    IT doesn`t matter which one you plug into ....I always plug into the bottom and jump to top and bottom posts with my DYI jumper cables
    see...!
    now you have two posts !!!!!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • phipiper10
    phipiper10 Posts: 961
    make your own - it's "fun" and easy. It was my first DIY audio project and I reached my DIY limit on the project;)
    Here's the link from my "early days"
    http://www.polkaudio.com/forums/attachment.php?attachmentid=14554&d=1141008735
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • beardog03
    Phip....
    Those look just like the ones I made !!
    Made me feel like I knew what I was doing !!!
    THey actually work very well.....:cool:
    Don`t buy them, make them....;)
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
