further bi-wiring questions
928man
If you have speakers that are bi-wireable but do not have jumpers can you make your own or is it better to buy aftermarket? Which input should you plug cables into (high or low) vs which ones to "jump" to?
Post edited by 928man on
Yes you can make them very easily...and it is IMPO better than the jumpers that come with the speaks...YMMV
IT doesn`t matter which one you plug into ....I always plug into the bottom and jump to top and bottom posts with my DYI jumper cables
see...!
now you have two posts !!!!!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
make your own - it's "fun" and easy. It was my first DIY audio project and I reached my DIY limit on the project;)
Here's the link from my "early days"
http://www.polkaudio.com/forums/attachment.php?attachmentid=14554&d=1141008735Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Phip....
Those look just like the ones I made !!
Made me feel like I knew what I was doing !!!
THey actually work very well.....:cool:
Don`t buy them, make them....;)Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
