RPTV Suggestions
edited February 2003 in Electronics
My parents want me to help them put a HT in their new house. They want a 50-53" RP HDTV widescreen. Any suggestions would be greatly appreciated.
Thanks- Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
Welcome!
    Pioneer elite HD-PRO530 (53")
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    How much oes that run? They are wanting to spend around $1800.
    Thanks- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
    It's a $5k unit, with street price of $4k. With the budget that they have, I would go with Mitsubishi 50" Rear-Projection HDTV Monitor, VS-A50.
    the mits 55 unit is around 2k
    WS-55311
    they make great units for the price. and if you want you can drop about 400 for a isf calabraton and it wil make it liik even beter.
    Sounds like the Mits is the way to go. Thanks guys!
    Ganzo- Still working on some $ for your SW, I'll keep you posted.
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
    if Pioneer Elite is out of the price point then Mitsubishi is the way to go.You can't find a better set at there price point.They rule the market there.
    vote for Mitsubishi
    Dan
    np it is just sitting and waiting for a good home.
    I also vote for Mitsubishi. I own the 46 inch 46809 HDTV and couldn't be happier. No problems so far (owned over a year).
    The Mitsubishi's have a narrower "sweet spot" for viewing than some of the other models; but once you're there you will be impressed.
    You should be able to find a Mits under $2k if you shop around.
    I was also impressed with the picture on the Panasonic models but ultimately chose Mitsubishi based on the value, reputation, and awesome picture.
    I've been happy with my 51" Hitachi. Got it about a month and a half ago.
Welcome!
Welcome!
