I got new IC's.....now I see.
jayman_1975
jayman_1975 Posts: 672
edited November 2007 in 2 Channel Audio
Wow..i just recieved my new set of Audio Art IC-3 IC's. Until now I had not used a really good set of cables. I thought that the $30 set i had bought from my local "stereo/furniture/appliance/car stereo/electronic/cell phone" dealer was a "decent" set. After adding my Arcam DV27+ to the equation i figured i needed to spend a little bit on some better IC's.
I hooked them up tonight and was immediately impressed. The bass is much more present and pronounced yet very controlled. I can't believe this is possible. The soundstage opened up considerably to the point where it just about sounds like some things are coming from outside the walls. Never heard this before....anywhere. I can hear things right beside my ears and even coming from behind me. I feel like i just lost my virginity again. For $85 for a half meter...this was a very good improvement to my system....almost more so than my $2500 player. If things get better than this I am just about tempted to go solely 2 channel.
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Post edited by jayman_1975 on
  • beardog03
    beardog03 Posts: 5,550
    coolo aint it ?
    what cables did you get ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • janmike
    janmike Posts: 6,146
    Congrats. Funny thing, you never know until you try. I know the feeling.
    Michael ;)
    NORTH of 60°
  • beardog03
    the cable swap program taught me about cables / IC`s...
    Jesse turned me on to MIT !
    Thanks again Jesse !
    There is no going back now !
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 51,739
    Cables are cables, it's all in your head. :rolleyes:
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    Congrats on discovering the truth!
  • jayman_1975
    THanx....I would have to say i would have been on the "all in your head" side of the fence. Not anymore.
    Arcam CD37
    Vandersteen V2W
  • Yashu
    Yashu Posts: 772
    Cables are like subtle tone controls for your system. Radioshack Golds actually sound good compared to my expensive sets, that was a surprise, however, one expensive set sounds considerably worse than anything else...
  • Ferres
    Ferres Posts: 310
    Cool.
    I was once very skeptical with benefits of branded IC's whether they made a difference, I already had a pair of Nordost red dawns. That is until I got some fairly priced Chinese stuff that blew the Nordost's out of the water.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • marvda1
    marvda1 Posts: 4,943
    the audio art sc-5 speaker cables are also quite nice sounding.
    Puritan PSM156
  • danger boy
    danger boy Posts: 15,722
    it's just snake oil.. but good snake oil. ;)
    enjoy your cables.. i'd be interested in giving them a try.
    Pssst, cables DO make a difference
    PolkFest 2012, who's going>?
    tonyb Posts: 33,072
    CONGRATS!!Sounds like your a happy camper.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    glad you are now getting your two channel groove on, it is cool when everything comes together and you get those feelings, as you said getting the cherry popped again is rather grand.
    RT1
  • Yashu
    Yashu Posts: 772
    Haha, can we say that synergy can be orgasmic, in a way?
    I wanted to correct that by RS Golds I meant the old ones, the ones they just discontinued. The old ones have these nice gold plated plugs and black wire casing. The really old ones sound better than the recent old ones. The really old ones aren't as thick. Anyway, they are discontinued and you can only find them occasionally in RS stores, stock that hasn't been bought out, most of the time it is the 6 and 12' sets, but after going to 5 radio shack stores, I only found one with 3' sets, and I bought the last two.
    The new golds are crap, the plugs are weak and plastic with only gold plating on the inside, and they don't sound so good. RS always discontinues their good products, this being one of them, and that 50w amp, and we can't forget the LX speakers with the ribbon tweeters.
    Anyway, I was surprised at how well they sounded compared to my Wireworlds and Vampire Wires. They are definitely better than the Vampire Wires that I have, but about on an equal plain as the Wireworlds... and the price can't be beat... if you can find them. (maybe check ebay)
    I have tried other cables too... The highest end AR cables, nothing to phone home about there, good cables but I didn't like the sound, and I have tried some other higher end cables but could not justify the price given my system.
    The guy that makes my tube buffer, Ian Grant, this is what he uses in his main system... the old RS golds over all the highest end cables. I found it odd until I actually dug out my old cables and tried them... it was a shock, and I had to go out in search for enough to hook up the buffer and the DAC.
    IF you are looking for the most transparent cables at a good price, Vampire Wire makes some good cable, but be ready to hear everything, even what you may not want to hear.
  • jayman_1975
    Thanx for all the replies. I am soo pumped about my system now. Sucks that i already can't wait to better it even more. I'm sure that with what i have now....my speakers are the weakest link.
    The dealer that I bought the IC's from offered me a one year trade in on these at full price. I couldn't resist. Try them for a year and send them back to get something a little higher end? Geez...that's a heluva deal. But so far...i'm tickled with these.
    I'm using middle of the line Audioquest speaker cables. These are the only ones i've tried besides cheap stuff from walmart. They seem to sound good to me. I wonder though....the new IC's are silver....should the speaker cables be silver as well to properly mesh? Any thoughts??
    Arcam CD37
    Vandersteen V2W
  • ND13
    ND13 Posts: 7,601
    He once was blind, but now he sees.
    Congrats for being open-minded enough to hear for yourself and not being a sheep.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • danger boy
    you can go with silver speaker wires.. but in my opinion and experience with them.. is that you wouldn't gain much or anything really from going with them. the big difference as you have just found out is in interconnects..
    I use a local guy's copper with silver plating interconnects too.. much better balance in highs, mids and lows over pure silver ic's. so much silver can be to bright.... i've been there with pure silver wires. to expensive and to bright.
    stick with good copper speaker wires.. and i'm sure it will balance out nicely with your new iC's :D
  • Face
    Face Posts: 14,340
    Silver I/C's aren't always bright. I have 2 different pure silver I/C's here made by the same company, one is bright, the other is neutral to dark.
  • danger boy
    I would think silver interconnects would work well with the LSi speakers... :) anyone try this combo?
  • madmax
    madmax Posts: 12,434
    Cables can certainly sound different.
    madmax
    Vinyl, the final frontier...
  • Yashu
    Yashu Posts: 772
    Speaker cables are higher level signals, whereas ICs are low level signals... so, ICs should make the most difference, since there is more room to screw up the signal... since there is less of it to work with.
  • marvda1
    the ic-3's and sc-5's are made of sliver plated copper not all silver.
    Puritan PSM156
