PS3 Question about HDMI/component
Serendipity
Serendipity Posts: 6,975
edited November 2007 in Video Games
Can the PS3 output full resolution over component video? Or do you need to have an HDMI-capable display?
My CRT projector only has component video and RGBHV.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • cheddar
    cheddar Posts: 2,390
    I'm pretty sure you'll run into DRM problems with 1080p blu-rays. But games might be ok. Not sure though...
  • Serendipity
    So you're saying to play blu-ray at full resolution you MUST use HDMI?
  • bdaley6509
    bdaley6509 Posts: 1,167
    I believe 1080i is max for component, and 1080p for HDMI. If your TV upconverts 1080i to 1080p like my Sony, component is fine.
  • Serendipity
    bdaley6509 wrote: »
    I'm using a Sony VPH-D50Q CRT Projector which does not upconvert 1080i to 1080p. So from what I understand with games I will be able to get 1080i, but with blu-ray I am limited to using the HDMI port?
    Is this correct?
  • Pablo
    Pablo Posts: 723
    I actually have the same questions (but I didn't want to start a new thread). I don't think there is a tv with only component inputs that can handle 1080p (is there?). My questions is;
    Does the PS3 even have component outputs? (from what I saw it was just HDMI for HD).
    If it does, will blue-ray movies play at all through component? (does the copyright protection prevent that, or did they finialy give up on that?).
    The same questions for the 360 (I know they have component outputs [or at least the cable], but will HD movies play through it?).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Yes the PS3 has component outputs, you just have to buy the proprietary style cable that plugs into the slot in the back. The same is true with the 360, except that you get the cables (componnt and HDMI) in the box).
    I don't know about the ability of either to play HD movies through component, I'm using HDMI on both of mine.
  • mutelight
    mutelight Posts: 1,054
    The PS3 will output up to 1080i for Blu-ray movies over component cables. Since you have a CRT projector it will only display interlaced images anyway since that is the way that the technology works. You should be all set. However, DVDs will only upscale if you use a HDMI interconnect.
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • BIZILL
    BIZILL Posts: 5,432
    ps3 plays 1080i through component. i've read you can use the component adapter from the ps2 on the ps3.
    the xbox 360 hd dvd player outputs 1080i through component just fine. if you don't have hdmi, the 360 also offers vga connection for 1080p.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
