Would a bad tube cause a buzz?
Sure all those low freq. bass waves bouncing around a 10 by 10 room isn't helping.
Rattleing the crap out of those tubes.Tv -amps-taylo's and see if it's gone.HT SYSTEM-
lsi 9's -
Was thinking he should try the same thing too.
But apparently the TV didn't produce any static, static only when the Candela was in the mix.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
So - looks like it's probably the Candela.
But maybe something with the Shanling too?polkaudio RT35 Bookshelves
I dunno ---
Outlaw will be back in a week or so...
Will hook it up then and see what happens...
Static remains -- fingers go back to the Paradigm or Shanling...
But oddly enough, the stock Candela tubes are flat out awesome -- much clearer than the other tubes I had...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I dunno ---
It may just be a combination of the Candela, Paradigm, or Shanling.
Since Shanling -> any amp produces static, and
Candela -> Stratos Monos produces static too.polkaudio RT35 Bookshelves
Vr3MxStyler2k3 wrote: »Static remains -- fingers go back to the Paradigm or Shanling...
If it were the Paradigm, then it doesn't explain why the Shanling is producing static when fed directly into any amp.
If I understand correctly, that's bypassing the Paradigm from the chain.polkaudio RT35 Bookshelves
But you also said when the Shanling was unplugged from the Candela, the static still persisted.
So if the Shanling is not even plugged up, how could it be producing static?
Hmm...
This makes no sensepolkaudio RT35 Bookshelves
the funny thing is that the only thing that hasnt changed in the cables2 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
Sure,a bad tube can cause a buzz........
But so can a bottle of Jack and a big fatty.
I tend to believe your problem is the later.HT SYSTEM-
lsi 9's -
I'm not sure what the cause is --
Will know more once the Outlaw returns so I can try a different preamp -- if it persists, will have to track down a cheap DVDP to plug up in place of the Shanling...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Remember, I have a bud that's about twelve miles away from you that has one of my pre's he's not using anymore.............
Get 'er done!
Vr3MxStyler2k3 wrote: »I'm not sure what the cause is --
What happened to the Cambridge?polkaudio RT35 Bookshelves
As for a source, save your loot. Gee whiz, I have plenty of gear I can loan you to help you figure this out. I'm in Matthews almost everyday, so maybe we can work something out. Kuul?
Trust me tonyb, it's not that.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Also, can you get a cheap DVDP from CC or BB or Wal-Mart just for testing purposes?
I have a $20 DVDP - analog out is pretty good, no buzz. Nowhere near the quality of my Onkyo, but still, for $20, the sound quality is good.polkaudio RT35 Bookshelves
Long shot. Have you checked any of the suspect equipment for a loose chassis ground? Something that could possibly introduce noise through the power TX's? Loops?
Just a thought.
Russ -
Just a thought.
Russ
Was thinking the same thing too.
Trey - do you plug all your audio gear into the same phase on your circuit breaker?
But I'm still suspecting it's the Shanling, Candela, or Paradigm. Or any combination of the above.polkaudio RT35 Bookshelves
It's probably an earwig in his left ear.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Outlaw will be here Wednesday -- assuming I can find someone to chill out here if it dosnt arrive before I have to go to work....
That will allow me to test out the preamp --
Plenty of cheapy DVDPs around here to put into the loop...
Thanks for the offer though broham- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I'll try it without the crossover in the loop tommorow....
After working on the system for... 6 hours troubleshooting --
I was in the mood to just tear everything apart and do some new wire managment to go around with the PC --- much MUCH easier to manage my cables now...
Well after looking at the picture you posted, the problem is pretty obvious and it is actually two-fold. First, that little deer figurine in the corner is picking up stray RF signals and sending it to straight to the tubes. Secondly, that little toy figure at the bottom right is aiming it's laser weapon straight at your gear, causing the static you are complaining about.
Joe (glad to be of help)Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
joeparaski wrote: »Well after looking at the picture you posted, the problem is pretty obvious and it is actually two-fold. First, that little deer figurine in the corner is picking up stray RF signals and sending it to straight to the tubes. Secondly, that little toy figure at the bottom right is aiming it's laser weapon straight at your gear, causing the static you are complaining about.
No, it's the light bulbs in his ceiling fan. Just replace them and you'll be fine.polkaudio RT35 Bookshelves
Actually, the static is due to your neighbor's new wireless router.polkaudio RT35 Bookshelves
You are all wrong. It's operator error.
Eh -
Efffff you!
It might be, at this point, I'm just giving up until the Outlaw arrives- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hehe.
I here you. Hopefully the diagnosis will only take 5 minutes instead of six hours.
Try the tweaker pebbles.....
No loose grounds or loops....?? -
Try the teleportation tweak.polkaudio RT35 Bookshelves
Well - Outlaw came in today, quickly hooked it up using the Candela's HT bypass
And something is seriously effed in my Candela -
Using the HT bypass, you should have to select it to HT to hear the Outlaw --
Not the case, I could hear it on every single input, at half volume...
If I turn off the Outlaw, my volume on CD is shut in half...
So I called Klaus - Mike was there, no Klaus... awaiting Klaus to call back...
Ah well...
Preamp troubles in Sidland..
But Outlaw is rock solid, repaired the 990 in about 2.5 weeks, paid for shipping back --- repaired it for free --- and threw in a pack of playing cards...
Awesome stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Well - Outlaw came in today, quickly hooked it up using the Candela's HT bypass
Ah well...
Awesome stuff
You can hear the Outlaw on every input in the Candela?
Something is seriously messed up with the pre.
P.S. I got the playing cards too from Peter Tribeman.polkaudio RT35 Bookshelves
