Should i modify my RTi's?
GSRBOB
GSRBOB Posts: 172
edited December 2007 in DIY, Mods & Tweaks
I'm so bummed.:( I just found out that the replacement tweet's r $90 a piece on my RTi 10's and CSi5. Now i'm considering buying different tweeters and retrofitting them. Has anyone done this to there's? Oh and thanx in advance for any positive advice.
My first post! Did'nt see an intro section.
Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
Pwr- Monster HTS 3600
LCD- KDL-40XBR2
  • m00npie
    m00npie Posts: 697
    edited November 2007
    GSRBOB wrote: »
    Clubhouse
    Welcome!!
  • GSRBOB
    GSRBOB Posts: 172
    Thanx.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Why are you needing to replace them?
    You need to bite the bullet, and get the correct parts.
  • GSRBOB
    GSRBOB Posts: 172
    They no longer work. I also thought about buying another set of RTi 6's or 4's because they are close to the same price i would pay for two tweeters, and then just buy the tweet for the CSi5.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • PolkThug
    PolkThug Posts: 7,532
    All three no longer work?! What happened?
    This isn't something silly like the jumpers were removed, right?
  • GSRBOB
    GSRBOB Posts: 172
    I'm embarrased to say i blew them.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • m00npie
    m00npie Posts: 697
    GSRBOB wrote: »
    Dare I ask how?
  • GSRBOB
    GSRBOB Posts: 172
    My ears r still ringing:D
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • MSALLA
    MSALLA Posts: 1,602
    Distortion?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • dorokusai
    dorokusai Posts: 25,642
    I would suggest buying the correct drivers as well. If you don't want to absorb the cost, different drivers are not a solution, just a band-aid and they often sound awful.
    There's more to loudspeaker design than the speaker in play here, as the crossover was also developed around the factory speaker. It's not just about dropping in something that fits.
    Let us know what you do or want to do.....
  • WilliamM2
    WilliamM2 Posts: 4,812
    Why not use the waranty?
  • GSRBOB
    GSRBOB Posts: 172
    Cant find the reciet.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • Sherardp
    Sherardp Posts: 8,038
    m00npie wrote: »
    Dare I ask how?
    My thoughts exactly, can you tell us what happened. Were you rocking them out that loud? I can only imagine how much noise you were making with them, those things go insanely loud. What AVR are you using on them?
  • GSRBOB
    GSRBOB Posts: 172
    Ya i got a little carried away. My AVR is an Onkyo TX-NR801. I wish i would have gotten into an HK but Circuit City didnt have the one i wanted at the time. Now i have a different perspective on things. Id like to go with seperate amplification. The Sunfire products look good just havent really researched yet. Nice setup by the way.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    LCD- KDL-40XBR2
  • obieone
    obieone Posts: 5,077
    You don't need a receipt. The warranty is thru Polk, not Circuit city.Do you still have the boxes the speakers came in? they should've come with a warranty card?
  • dorokusai
    Hold your horses Obieone, as a receipt and/or proof of purchase is required for warranty coverage from every manufacturer on the planet. When it comes to Circuit City, they often handle warranty claims onsite but that may have changed over the past year. The consumer has the option of handling it with CC or directly with the manufacturer.
    GSRBOB - I would suggest you contact Polk Customer Service and see what they are willing to do for you sans receipt. If you sent in your warranty card, you should be just fine.
    polkcs@polkaudio.com
    9am - 6pm, M-F, EST (USA)
    800-377-7655 toll free phone
    410-764-5470 fax
  • tgw323
    tgw323 Posts: 1
    With their computer, CC should have a record of when you bought them.
  • beardog03
    beardog03 Posts: 5,550
    Listen to Mark....he wouldn`t steer ya wrong..
    any other option you were concidering is just foolish...IMO
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    I looked up the specs on the Onkyo TX-NR801, it shows 100 w/channel.
    The Rti8 shows efficiency at 90db.
    The Csi5 shows efficiency at 90db.
    I can see why your ears were ringing.
    You're not going to save that much money by going with "It'll-Fit" replacement tweeters, and you'll kick yourself in the rear if you do.
    As others have mentioned, get ahold of Polk; if you have the warranty cards from the box, you should be good to go.
    Our 7.1 system is powered with a Lil' Onkyo (503) at 75 w/channel. After 4 months of keeping the reins on the horse, we (okay, I) decided let's see what she'll do.
    "Fast and Furious". Our speakers have similar efficiency ratings (lower on the ladder, mind you), but the railroad track scene was played at max volume with the grills off all speakers.
    The Polks soaked it all up, and said "Thank you sir, may I have another".
    Knocked pictures off the wall, etc, so I can't imagine the sound level in your room to get 3 tweeters to blow.
    As others will tell you, fewer tweeters get popped with high power amps than vice versa.
    While deciding on the route you're going to go regarding tweeter replacement, you might want to check your speaker wiring hookup (any spare strands, etc).
    Good luck !
  • jfeinman
    jfeinman Posts: 29
    yeah, I'm curious too; how the hell did you blow those tweeters out, and on 3 different speakers? I run an Onkyo TX-SR703, with Rti6s, 4s, and a CSi3. I've cranked the amp full tilt, and never even heard distortion through them. My amp is 100 watts a channel, very very similar to what you were using. Sounds like something may be wrong with your amp or a distortion issue.
    That being said, I supervise over at CC, and we keep good records of purchases. Basically, if we took down your name, or you know the credit card you used, we'll have a record of it (I've dug up stuff from purchases 15 years ago). The problem though, is that we haven't carried RTi in close to 5 years, so your speakers might be out of warranty anyhow.
    Replace those tweeters with the proper ones. If you try to cheap it out, you'll probably still spend a decent amount on the tweeters, and end up with something that sounds worse than cheapo speakers that cost less than your replacement tweeters.
