Would a bad tube cause a buzz?
1235
    tonyb Posts: 33,072
    edited November 2007
    Sure all those low freq. bass waves bouncing around a 10 by 10 room isn't helping.
    Rattleing the crap out of those tubes.Tv -amps-taylo's and see if it's gone.
  • Serendipity
    Serendipity Posts: 6,975
    tonyb wrote: »
    Was thinking he should try the same thing too.
    But apparently the TV didn't produce any static, static only when the Candela was in the mix.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    So - looks like it's probably the Candela.
    But maybe something with the Shanling too?
    VR3 Posts: 29,442
    I dunno ---
    Outlaw will be back in a week or so...
    Will hook it up then and see what happens...
    Static remains -- fingers go back to the Paradigm or Shanling...
    But oddly enough, the stock Candela tubes are flat out awesome -- much clearer than the other tubes I had...
  • Serendipity
    I dunno ---
    It may just be a combination of the Candela, Paradigm, or Shanling.
    Since Shanling -> any amp produces static, and
    Candela -> Stratos Monos produces static too.
  • Serendipity
    If it were the Paradigm, then it doesn't explain why the Shanling is producing static when fed directly into any amp.
    If I understand correctly, that's bypassing the Paradigm from the chain.
  • Serendipity
    But you also said when the Shanling was unplugged from the Candela, the static still persisted.
    So if the Shanling is not even plugged up, how could it be producing static?
    Hmm...
    This makes no sense
  • JimBRICK
    JimBRICK Posts: 1,543
    the funny thing is that the only thing that hasnt changed in the cables
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
    tonyb Posts: 33,072
    Sure,a bad tube can cause a buzz........
    But so can a bottle of Jack and a big fatty.
    I tend to believe your problem is the later.
    VR3 Posts: 29,442
    I'm not sure what the cause is --
    Will know more once the Outlaw returns so I can try a different preamp -- if it persists, will have to track down a cheap DVDP to plug up in place of the Shanling...
    treitz3 Posts: 20,010
    Remember, I have a bud that's about twelve miles away from you that has one of my pre's he's not using anymore.............
    Get 'er done! :p
  • Serendipity
    What happened to the Cambridge?
    As for a source, save your loot. Gee whiz, I have plenty of gear I can loan you to help you figure this out. I'm in Matthews almost everyday, so maybe we can work something out. Kuul?
    Trust me tonyb, it's not that.
  • Serendipity
    Also, can you get a cheap DVDP from CC or BB or Wal-Mart just for testing purposes?
    I have a $20 DVDP - analog out is pretty good, no buzz. Nowhere near the quality of my Onkyo, but still, for $20, the sound quality is good.
  • lightman1
    lightman1 Posts: 10,796
    Long shot. Have you checked any of the suspect equipment for a loose chassis ground? Something that could possibly introduce noise through the power TX's? Loops?
    Just a thought.
    Russ
  • Serendipity
    lightman1 wrote: »
    Just a thought.
    Russ
    Was thinking the same thing too.
    Trey - do you plug all your audio gear into the same phase on your circuit breaker?
    But I'm still suspecting it's the Shanling, Candela, or Paradigm. Or any combination of the above.
  • dorokusai
    dorokusai Posts: 25,576
    It's probably an earwig in his left ear.
  • lightman1
    dorokusai wrote: »
    Nasty little buggers, aren't they?:mad:
  • Serendipity
    lightman1 wrote: »
    HAHA!
    VR3 Posts: 29,442
    Outlaw will be here Wednesday -- assuming I can find someone to chill out here if it dosnt arrive before I have to go to work....
    That will allow me to test out the preamp --
    Plenty of cheapy DVDPs around here to put into the loop...
    Thanks for the offer though broham
  • joeparaski
    joeparaski Posts: 1,865
    I'll try it without the crossover in the loop tommorow.... :)
    After working on the system for... 6 hours troubleshooting --
    I was in the mood to just tear everything apart and do some new wire managment to go around with the PC --- much MUCH easier to manage my cables now...
    Well after looking at the picture you posted, the problem is pretty obvious and it is actually two-fold. First, that little deer figurine in the corner is picking up stray RF signals and sending it to straight to the tubes. Secondly, that little toy figure at the bottom right is aiming it's laser weapon straight at your gear, causing the static you are complaining about.
    Joe (glad to be of help)
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Serendipity
    joeparaski wrote: »
    No, it's the light bulbs in his ceiling fan. Just replace them and you'll be fine.
  • Serendipity
    Actually, the static is due to your neighbor's new wireless router.
    You are all wrong. It's operator error. :p
    VR3 Posts: 29,442
    Eh -
    Efffff you! ;)
    It might be, at this point, I'm just giving up until the Outlaw arrives
    Hehe.
    I here you. Hopefully the diagnosis will only take 5 minutes instead of six hours. ;)
  • lightman1
    Try the tweaker pebbles.....
    No loose grounds or loops....??
  • Serendipity
    Try the teleportation tweak.
    VR3 Posts: 29,442
    Well - Outlaw came in today, quickly hooked it up using the Candela's HT bypass
    And something is seriously effed in my Candela -
    Using the HT bypass, you should have to select it to HT to hear the Outlaw --
    Not the case, I could hear it on every single input, at half volume...
    If I turn off the Outlaw, my volume on CD is shut in half...
    So I called Klaus - Mike was there, no Klaus... awaiting Klaus to call back...
    Ah well...
    Preamp troubles in Sidland..
    But Outlaw is rock solid, repaired the 990 in about 2.5 weeks, paid for shipping back --- repaired it for free --- and threw in a pack of playing cards...
    Awesome stuff
  • Serendipity
    Ah well...
    Awesome stuff
    You can hear the Outlaw on every input in the Candela?
    Something is seriously messed up with the pre.
    P.S. I got the playing cards too from Peter Tribeman.
