Would a bad tube cause a buzz?
1246
    treitz3 Posts: 20,012
    edited November 2007
    Not sure if that eliminates the PC or not...
    Not necessarily.
    It could be a combo of plug-ins or just two that can cause something like this. Try to plug everything in the way you had it before w/o the PC. At least to the best of your knowledge.
    VR3 Posts: 29,443
    Thanks guys for ALL the help - I appreciate it 100%!
    Hopefully me and Klaus can figure it out from here... may have to send it his way and live off the Zune for a while ;)
    VR3 Posts: 29,443
    Hmm - If I just unplugged everything except the Pres/CDP/Amps - would that work?
  • Serendipity
    Serendipity Posts: 6,975
    One more thing, you said the Shanling plugged directly into the monos produced static.
    How is it now?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    You know what? That might just work!
    VR3 Posts: 29,443
    If I run it with the Candela, the static does not increase at all between the Zune and Shanling when switching sources -- so it seems like the Candela is producing all fo the static...
    I can't explain the static from the Shanling --- kind of bothersome but I'll say this....
    The Shanling kicks the Zunes **** - 100% --- no comparison...
    VR3 Posts: 29,443
    I lined up two of the exact same songs, lossless transfer on the Zune -- dynamics, clarity, everything IMMEDIATELY goes to the Shanling
  • Serendipity
    There is static from the Shanling -> monos, right?
    I'm still thinking something's up with the Shanling.
    That would simplify things.
    If you get the gumption...try it. Plug in the way you best remember and rotate/switch if necessary. If this doesn't work, then we are down to nill for components.
  • Serendipity
    Also, what's odd is that the Shanling -> Crown is also producing static. That's with eliminating everything else in the path.
    VR3 Posts: 29,443
    Well -- lol.. you guys are going to laugh
    Before I had...
    A four outlet extention on the wall and two electrical components off that -- one plugged into the other...
    Ran the TV, amps, pre, cdp, xbox, fan, cable, crossover, anything within reach of that outlet off one thing... ;)
    So -- can't really re-create that.... hehe
    VR3 Posts: 29,443
    Actually the Crown only produced static with the Shanling at FULL GAIN
    At mid gain, the Shanling produced nothing - thats also with the Shanling at FULL VOLUME
    See -- with the Monos, they are always at full gain -- 100%
    So perhaps when you turn down the Shanling volume, you get all of the static that can be picked up...
    Like I said, bothersome -- but makes sense in perspective to gains (atleast to me in my bewildered trying to just rationalize everything that just happened state)
  • Serendipity
    Before I had...
    But it worked, right?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Bad tube in the Shanling produces some noise when run straight into the amps, but when amped up by the preamp by 15db more gain, it is out of control once it gets to the Monos.
  • Serendipity
    Still not supposed to happen. When I had my Adcom GFA-535, it was always at full gain (100%), and when connected to my TV or even a cheap $20 DVDP (with variable audio out), there was no static whatsoever. Also same thing with a DJ mixer.
    VR3 Posts: 29,443
    This is a very good point -- I will remove the tubes fromt he Shanling and see what happens...
    Only question I have is --
    Why would the same static be audible with the Zune and the Shanling, particulrly when the Shanling isnt even plugged up?
    Its a very weird situation, I've been scratching my noggin ALOT though
  • Serendipity
    Well, when the Shanling isn't even plugged up, you have nothing connected to the input, right?
    In Electrical Engineering class we always terminate unused connectors - for example, a SCSI terminator for the PC.
  • Serendipity
    I know it shouldn't be, but apparently when the Shanling isn't even plugged up to the Candela, you are getting static.
    Weird.
    And going back a few posts, the Shanling produces the most static at ZERO volume and max gain on the Crown?
    Why would the same static be audible with the Zune and the Shanling, particularly when the Shanling isn't even plugged up?
    Try it.
  • Serendipity
    Monos + Shanling + Speakers + Nothing Playing (Stopped) = No Noise
    Monos + Shanling + Speakers + Something Playing = HOLY EFFING JESUS CHRIST'S SISTER IN HOLY JOSEPH I'M ABOUT TO BE KILLED NOISE
    So there is a lot of noise when the Shanling is plugged directly to the monos, but the same noise is there when going through the Candela?
    VR3 Posts: 29,443
    I went in order basically with the Zune ---
    Zune to Amps
    Zune to Crossover to Amps (First instance of static)
    Candela to Crossover to Amps (Zune As An Input) (Most Static Present)
    Candela To Crossover to Amps (Zune AND Shanling as Inputs) (Same Static As Previous Arrangement)
    This is what leads me to believe that the Candela is producing the static...
  • Serendipity
    Hmm, in my previous post you said there was a LOT of noise from the Shanling.
    Sure, the Candela may be producing the static, but there still shouldn't be "I'M ABOUT TO BE KILLED NOISE" from the Shanling.
  • Serendipity
    Zune to Amps
    Then maybe there is a problem with the Candela.
    VR3 Posts: 29,443
    appadv wrote: »
    :p
    I think that may be the case ;);)
  • Serendipity
    Get some sleep and hope it works tomorrow. I'm literally falling asleep in front of the computer.
  • Serendipity
    Just thinking -
    Maybe something in the CDP affected the Candela?
  • Dennis Gardner
    Zune to Amps
    If Zune to Amps = no noise then.......
    According to this statement, the crossover is bad and the preamp boosts the badness into the amp which boosts it more. This must be true since it is independent of source.
    The reason for the noise being less with Zune-C/O-Amp is that the Zune is putting a clean signal into a passive noise maker (CO). The noise isn't amplified with the signal only added.
    With the Candela added, once noise is in the signal path from the CO, the preamp adds more gain to both noise and signal, then the Monos amplify that hotter signal again. Noise is growing exponentially within the signal path as voltage rises. You are basically getting a higher noise to signal ratio with each boost.
    This is precisely why you try not to stack preamps or use headphone outs when a fixed line level output is available. Noise gets induced.
    VR3 Posts: 29,443
    I'll try it without the crossover in the loop tommorow.... :)
    After working on the system for... 6 hours troubleshooting --
    I was in the mood to just tear everything apart and do some new wire managment to go around with the PC --- much MUCH easier to manage my cables now...
  • JimBRICK
    JimBRICK Posts: 1,543
    I had the same problem with my nad receiver I changed out analog cables and problem went away. sounded like an annoying humming from speakers that you could hear no matter how loud you had it. I disconnected the cables running from my satilite receiver and the problem went away. Just a thought
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • lightman1
    lightman1 Posts: 10,796
    Trey, I'm only 15 miles from you and I'll be more than happy to take away all this stuff. Just so you can get some peace. I'll "dispose of it".
    Here to help,
    Russ
