Would a bad tube cause a buzz?
VR3
VR3 Posts: 29,401
edited November 2007 in 2 Channel Audio
Please say so...
If not, I may throw my entire stereo out in the yard....
I turn off my Candela - the buzz goes away...
I tap on the faceplate/top I hear a static as I knock from the speakers...
Tell me I have a bad tube...
Something...so I can go back to sleep
Post edited by VR3 on
«13456
  • TitaniumMan
    TitaniumMan Posts: 93
    Yes, a bad tube can buzz and react to tapping on the faceplate. When I had tube gear, I made it a habit to have at least three spares for almost every tube in the system.
    Ya think that may be why I'm broke?
    VR3 Posts: 29,401
    I have spare tubes - lol
    Just not enough patience at 5:30am to change them ;)
    I just turned it off... lol
    Finally went back to sleep an hour later lol - and now I gotta go to work
    But thanks
    I'll change them out tonight!
    tonyb Posts: 33,069
    5 am?? AHHHHH......to be a young bass freak again...:)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    how's that gotee coming for you there Trey???
    the tube is the most likely culprit, certainly sounds like at least one is microphonic. Sometimes the piece can start off quiet then get noisy as the tube heats up.
    RT1
  • dorokusai
    dorokusai Posts: 25,576
    Start wacking it with a pencil.
  • JimBRICK
    JimBRICK Posts: 1,543
    try pouring water on it
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
    heiney9 Posts: 25,423
    dorokusai wrote: »
    What IT are you referring to? :D
  • RuSsMaN
    RuSsMaN Posts: 17,986
    All tubes are microphonic, some just more than others.
    VR3 Posts: 29,401
    Ok...
    So I changed the tubes...
    And it actually got worse....
    Odd --
    Go from there ---
    Totally disconnect the pre...
    Attach the CDP directly to the amp...
    When a CD is NOT playing -- it is kind of quiet, a very slight static...
    When a CD is playing, all hell breaks loose...
    I'm starting to point fingers at the Mono Blocks...
    VR3 Posts: 29,401
    Update 1-
    Disconnected the CDP...
    Connected it directly to TV
    Slight static (I would give it on a loudness scale a 3 out of 10)
    And when the CDP is plugged up only - cd playing, a 10...
    From there --- if everything is hooked up normally, no CD playing -- and even on a different source, I will have to say its on a scale of 5....
    Nothing makes sense right now
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Tube CD player............I would check the tube sockets in it. I know you don't use that output, but it doens't turn them off.
    VR3 Posts: 29,401
    Update 2 -
    Connected preamp to amps -- no CDP in chain
    Noise continues
    CDP is dismissed from possible causes...
    Amps remain the probable problem...
    F*CK
    VR3 Posts: 29,401
    Update 3 -
    Is not a power related noise
    Bought power conditioner today -- problem persists...
    EDIT -
    "HEARD A slight "POP"" --- noise INCREASES to intermitent static
  • Dennis Gardner
    How about the 990?
    VR3 Posts: 29,401
    990 isnt back from Outlaw yet -- in transit..
    Only thing plugged up right now...
    Amps, Pre, TV - Crown XTi1000 is turned off --- but that shouldnt cause any noise...
    VR3 Posts: 29,401
    I just disconnected the Crown all together, noise persists...
  • Dennis Gardner
    Run the TV directly into the amps if you can contol the volume of TV. This tests just the amps.
    VR3 Posts: 29,401
    I did ---
    Hard to tell exactly...
    If I muted the sound -- I heard a slight static... not to the extent I am hearing it now....
    Its hard to tell if there is static going on when the TV sound is on...
    I don't think its the preamp -- reason being when I plugged the CDP up, it basically went to hell...
    I dont know - trying to call Klaus, no answer
  • Dennis Gardner
    Is it both channels? I doubt both amps go bad at the same time.
    VR3 Posts: 29,401
    Right channel is WORSE than the left channel...
    The right channel has a higher volume of static and is more intermitent - as in its a variation of static - not a continuous static....
    The left channel is a constant static at a lower volume
    Nothing really makes much sense right now
  • Dennis Gardner
    Bad signal or power somewhere. Both amps won't crap out together. Check all cabling.
    VR3 Posts: 29,401
    I swapped the left and right outputs on the preamp ---
    There is still a slight static in the left speaker and a much louder static in the right...
    - but it no longer an intermintent static... hmmm --
    Weird....
    Sounds like the amp powering the right channel is blah
    And the amp powering the left channel still has static -- but not near as much... not sure - not sure not sure
    VR3 Posts: 29,401
    One thing to point out -
    This static does NOT increase when you increase the volume
    Its a constant static no matter what...
  • Dennis Gardner
    Try the preamp into your Crown into your Taylos.
  • Serendipity
    Serendipity Posts: 6,975
    Trey,
    Try to run the TV's audio out directly into the amps again.
    TV -> Amps -> Taylos
    Then switch the left/right monoblocks and see if the problem persists on the same amp.
    I know you did this before but try it again just to be sure.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    VR3 Posts: 29,401
    Plugged up Crown --
    Zero noise issues
    VR3 Posts: 29,401
    Yep --
    Absolutely no noise issues coming from the Crown
    Looks like the Monos are having some MEGA issues...
  • Serendipity
    That basically says it's the monoblocks.
    However, like I said, try the TV's audio out into the monos again. Sometimes weird things just creep up...
    Oh yeah, if possible, connect your CDP to one of the "Audio/Video In" inputs on the TV. What happens then?
  • Serendipity
    Trey,
    It's nearly impossible for TWO amps to go out at the same time. Literally. If it were just one monoblock, yes, possible, but TWO?
    VR3 Posts: 29,401
    Hey
    It makes as much sense to YOU
    as it does to ME
    lol
