What's the best internal wire for speakers?
Ricardo
Ricardo Posts: 10,634
edited November 2007 in Vintage Speakers
I am rebuilding my monitor 7's, and want to change the internal wire. Any recommendations? Don't want to spend a fortune...just want to get the right wire.
Thanks!!!!!!
SOPA
Post edited by Ricardo on
    heiney9 Posts: 25,612
    Ricardo wrote: »
    Thanks!!!!!!
    Not sure it really matters beyond using a decent guage. When I redid my 5b's I used blk/red 16g copper zip wire from Parts Express. Having it color coded helped ensure phase remained constant while rewiring the drivers, etc.
    I was not able to rewire from the terminal cup to the x-over board because of the large amt. of gloppy glue used to seal the cup. It would have taken quite the elbow grease to get it all off.
    Good luck
  • Ricardo
    Thanks; I don't really want to change the gauge (at least not much). I really want to know what's the right/best type of wire. I am not changing it to improve or experiment. I am changing it because it is corroded...
    I'll look up Parts Express. They are actually close by :)
    SOPA
  • Face
    Face Posts: 14,340
    Why not Mac CuQ Speaker Wires? ;)
  • 33535403
    33535403 Posts: 13
    Ricardo wrote: »
    Thanks!!!!!!
    The best wire is BRAIDED GOLD WIRE followed by SILVER BRAIDED WIRE. Why braided? Electicity,current travels outside or around the surface of the wire--the more braids, the more travel surface. Why gold or silver? Because gold is number 1 conductor (2nd to the ??Borazon??), and silver is number 2 conductor. I heard from my physics teacher a long time ago this material called Borazon (Borason??), but I am not sure what it is.
  • read-alot
    read-alot Posts: 812
    33535403 wrote: »
    You must have had the same teacher as Hearingimpaired.
    Gold is slightly better than aluminum as a conductor, silver is best.
    http://www.polkaudio.com/forums/showthread.php?t=57133
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • dorokusai
    dorokusai Posts: 25,627
    Parts Express.
  • hypertone
    hypertone Posts: 150
    Actually solid copper is supposed to be a better conductor than stranded. There is more density in solid. More density = less resistance. The idea of the electrons only flowing on the outside surface of the wire (skin effect) does not apply to the audio spectrum, which is very low frequency compared to RF.
  • Face
    Face Posts: 14,340
    If possible, wouldn't you want to use the same type of cable from the amp to the speaker as you would inside the speaker?
    I'm going to have new cabs made up for my Tannoys and plan on running Goertz/Alpha Core cable from the x-over to the speakers. It'll probably cost more than the new cab though. :rolleyes:
    As for the Monitor 7c's I'm rebuilding, I may do the same, but with one of their lower lines of cable.
  • ND13
    ND13 Posts: 7,601
    barb-wire
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    uncoated coat hanger from your local dry cleaning establishment. Not too flexible but damn sturdy. ;)
  • Face
    Face Posts: 14,340
    Great advice. :D
