my first review
marvda1
check it out at www.stereomojo.com
http://www.stereomojo.com/MAC%20Cables%20Review/MACCablesReview.htm
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
Fair and unbiased. Great job, Marvin! You didn't pan them or gush over them. Gave enough info to let others judge for themselves. I'll check out a set myself soon and see.
Keep it up.
Lightman Russ -
Nice write up.
engtazengtaz
The first of many, many more Marvin. Great job!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Nice review.
I reviewed a few of the MAC cables in affordable audio ezine last month and came to same conclusion as you did about the Palladiums. Just awesome, natural sounding cables. Also as you indicated, it takes lots of time to demo different arrangements of cables because even switching ICs within your system can make a dramatic difference in the sound.
Interestingly, I just hooked up MAC power cables this evening for my HT pre and amp. I'm also using the Palladiums between the pre and CDP, and a single MAC Cu IC for the center channel. Great cables at great prices.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
hello early b., let me know what you think about the power cables.
marvinAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
marvin
I really like them. I've been using one on my amp for about three months. I tried it on my CDP, but it didn't work well there.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
have you noticed any of the slowing of tempo or cloudy sound in upper bass/lower midrange?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Nope. Although with the MAC PC on the CDP, it sucked the bass out, so it had to go.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I used the Palladiums I/C's for awhile.I thought they where good,but not great.Less bass,huge soundstage,tad bit less detail in the music.Might just be bad synergy for me with Macs.Z-squared makes some decent all around I/C's.HT SYSTEM-
