my first review
marvda1
marvda1 Posts: 4,904
edited November 2007 in 2 Channel Audio
Puritan PSM156
Post edited by marvda1 on
  • lightman1
    lightman1 Posts: 10,794
    Fair and unbiased. Great job, Marvin! You didn't pan them or gush over them. Gave enough info to let others judge for themselves. I'll check out a set myself soon and see.
    Keep it up.
    Lightman Russ
  • engtaz
    engtaz Posts: 7,664
    Nice write up.
    engtaz
    engtaz
  • RuSsMaN
    RuSsMaN Posts: 17,986
    The first of many, many more Marvin. Great job!
  • Early B.
    Early B. Posts: 7,900
    Nice review.
    I reviewed a few of the MAC cables in affordable audio ezine last month and came to same conclusion as you did about the Palladiums. Just awesome, natural sounding cables. Also as you indicated, it takes lots of time to demo different arrangements of cables because even switching ICs within your system can make a dramatic difference in the sound.
    Interestingly, I just hooked up MAC power cables this evening for my HT pre and amp. I'm also using the Palladiums between the pre and CDP, and a single MAC Cu IC for the center channel. Great cables at great prices.
    "God grooves with tubes."
  • marvda1
    hello early b., let me know what you think about the power cables.
    marvin
    Puritan PSM156
  • Early B.
    marvda1 wrote: »
    marvin
    I really like them. I've been using one on my amp for about three months. I tried it on my CDP, but it didn't work well there.
  • marvda1
    have you noticed any of the slowing of tempo or cloudy sound in upper bass/lower midrange?
    Puritan PSM156
  • Early B.
    marvda1 wrote: »
    Nope. Although with the MAC PC on the CDP, it sucked the bass out, so it had to go.
    tonyb Posts: 33,023
    I used the Palladiums I/C's for awhile.I thought they where good,but not great.Less bass,huge soundstage,tad bit less detail in the music.Might just be bad synergy for me with Macs.Z-squared makes some decent all around I/C's.
