Dolby TrueHD and DTS-HD?
It is normal. Apparently, it's because of very low noise content in HD sound tracks compared to standard DD/DTS sound.
Try watching Phantom of the Opera - you'll turn it up even higher.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Just talked with Denon support after a 45 minutes wait. I got a 3808 to take advantage of all the new audio formats, but as someone also posted, the AVR is not decoding True HD or DD+. All I get is "Multichannel In" in the screen. Also, I only get 5.1 in. I am using HDMI. My player is the HD-A30.
So I called Denon to complain that the AVR was not working as expected, or maybe I was doing something wrong.
The guy stopped me before I finished and said "I answer this question 10 times a day; Denon products have the capability of decoding all these formats, but there is NOT ONE HD or Blue Ray player in the market that can pass the new audio formats through HDMI!!!!!!!!". He started talking about some thechnical stuff but I was so pissed that did not pay attention.
WTF??? Toshiba is marketing their players as capable of passing these new formats :mad::mad::mad:
I need to call Toshiba but don't have the time right now. Will post additional findings later..._________________________________________________
As far as I know and someone correct me if I'm wrong, the only HD-DVD player that has the ability to pass Hi-Bitsream via HDMI is the HD-A35 and soon to be the XA2 via a firmware update.Money Talks, Mine says Goodbye Rob!!!!
Right; Toshiba confirmed that as of today, ONLY the HD-A35 is capable of passing the new formats to be decoded by the AVR. All others are passing "the players version" of the new formats, which is NOT the real thing. I asked him on firmware upgrades for the A-30, but he said he knew nothing.
Now, is it me and my poor English or this is NOT what the instructions and other literature say?
Obviously, I am going to return the A-30 and get the A-35._________________________________________________
I read over ay AVS that alot of people with the A35 couldn't tell any difference between the player decoding the new formats and there AVR decoding them.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
millerman 3732 wrote: »I read over ay AVS that alot of people with the A35 couldn't tell any difference between the player decoding the new formats and there AVR decoding them.
I agree, there should be no difference as long as the AVR provides the three levels of processing on incoming PCM signal (i-e Bass Management, Delay Management, Audessy EQ, converting 5.1 to 7.1).
I believe most AVR do the first two so there shouldn't be an issue along as you don't need to tweak signal via Audessy EQ or want to convert 5.1 to 7.1.
Ricardo, you don't need to change your player as you wouldn't get any audible benefits, Player doing the decoding or AVR doing the decoding is the same thing.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
If the DVD player makes the decoding all you can get is 5.1; Even the standard DTS 6.1 DVD's would only give you 5.1 if you let the player do the decoding. The A-35 can send encoded 7.1 channels to be decoded by the AVR, old or new audio formats. For me this is a good enough reason to get the A-35.
I'm getting mine tomorrow and sending back the A-30. Only a $50 or so difference in Amazon.
I'll let you guys know what True HD really sound like.
Edit: 5.1 to 7.1 simulations are not real 7.1 in my book....but I'll make the comparison._________________________________________________
only like 2 movies are 7.1 right now. so be sure to let us know how 'real' 7.1 sounds.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I know, but there are a lot of 6.1, and I expect that more will come
6.1 HD DVD's? I didn't think there where that many, and will the A30 not pass a 7.1 PCM signal over the HDMI output?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
millerman 3732 wrote: »6.1 HD DVD's? I didn't think there where that many, and will the A30 not pass a 7.1 PCM signal over the HDMI output?
No, I mean 6.1 standard DVD's. I have a few.
The A30 only passes 5.1 via HDMI._________________________________________________
Again, if my XA2 is connected to my preamp via 5.1 analog, the XA2 will process Dolby Digital Plus, Dolby TrueHD, and DTSHD MA, right? The preamp doesn't have decoders for those formats, but via analog letting the player decode will give me the new sound formats right?THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
Standard DVD's will pass all available formats as always, through the optical connection, or HDMI. The only limitations are on the new formats. -
that's correct... -
HDMI wil only pass 5.1 in HD and STD DVD's with the exception of the A-35._________________________________________________
I listen to everything now through 5.1 analog. I find it sounds much fuller. Exceptions , are a few 6.1 movies I have (SW -EX, LOTR 6.1).Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I have not compared with analog outputs from the DVD player to the receiver, but I can report that there is a significant difference between the new formats decoded by the DVD player and passed through HDMI to the receiver, and having the receiver decode them.
I made the comparison with 300, which has Dolby True HD. Differences were clear in:
-Louder bass. Had to turn gain down in my SVS. This not necessarily means that the sound is better.
-More "in there" sound achieved by a more involving surrounds participation. This definitely for me gives a plus to having the receiver decode._________________________________________________
The analog difference is amazing compared to the digital. The analog is much more even, vocals are better, dynamic range is better, there is better balance between speaker channels. On Transformers, the surround sound channels are clearer as is the center. I dont have to turn the AVR as loud to hear the quiet things, like talking or slight surround noises. I'm thinking its the player, because watching SD through the XA1, its better analog also. So when watching a disk, the HK ussually just stays on 6 channel direct.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Thats interesting. I watched Transformers again last night (HDMI on A30) and I dont know what the deal is with the movie but I have to run it at 5 on my Onkyo to get that volume up vs 15 on all of my normal movies.Testing
Testing
Testing -
Well from -80 to 0 ,on my HK, I ussually listen between -25 and -16, depending on the movie. But with 6 channel direct analog, I'm -35 to -25. So alot louder on analog and better sounding (with dynamic range and clearity)Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
As I've mentioned earlier - HD DVD will always have issues decoding DTS HD Master Audio because of authoring issues. The HD A35 was suppose to fix this but I have yet to hear it. Not all decoders are equal and therefore there should be audible differences between receivers and source players. The amount of total chaos within this thread is proof enough how poorly HD DVD and Blu Ray were marketed for audio quality improvements in the first place. People should be interested in the Bit-rates, not so much the extra channel of information.
The Samsung BDP 1400 needs a firmware upgrade to unlock the Bit-stream within the player for lossless. No Toshiba other then the newly released A35 supports bit-stream...no Toshiba player supports DTS MA decoding either...if you read the fine print the DTS HD support is core only (not master audio). -
I'm new to all of this and I have the AX2. Is this why in HD I always show PCM in my recievers window? I have the Pioneer VSX-74TXVi and I go HDMI to the reciever and from their to the TV. The TV is DVI, but I use a HDMI cable and attach a DVI plug to it for the TV (video anyway as the sound is handled by the reciever to the speakers). If I change the AX2 to Downmix PCM, the reciever will let me make any changes on output like I was showing standard DVD. If I change to PCM, then I get PCM (can't remember) IIx. If I watch in either Downmix or Multi, the sound has to be ajusted from -28 to around -16. So just where in all of this do I get True HD sound? Although I do hear a improvement overall when the movie is in DD plus. I guess that you have to have a new HD reciever and TV that does 1.3 HDMI to get the full True HD sound.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
nevermind
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Hey Ricardo, have you tried this out yet? is what this guy saying true, do you lose the secondary audio track when you let the AVR do the decoding? If this is the case I may be sticking with my HK a little longer than I thought.
Shane C. Buettner of "UltimateAVMag.com" said it didn't matter where the decoding was done.
http://ultimateavmag.com/surroundsou...ors/1007anthem
Quote:
As far as Dolby TrueHD and DTS-HD Master Audio goes, I know these are being sold as compelling events for which you should upgrade your AVR or pre/pro. This is false advertising. There is no performance advantage whatsoever we can see to decoding these formats in the AVR, and to the contrary there are some serious disadvantages. If you decode in the AVR or pre/pro you lose all secondary audio streams and cripple the interactivity features of both Blu-ray and HD DVD, and for no good reason.
And secondary audio isn't just obnoxious button click sounds in the menus. If you select a Picture-In-Picture stream, you'll get picture with no sound. Kinda takes the fun out of it. And again, there is no performance advantage to decoding in the AVR or pre/pro. As soon as an AVR or pre/pro decodes a compressed stream it in fact turns it into PCM for processing. We've heard no qualitative issues, so far, from doing this conversion in the player.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Sweet, I'm completely confused, think I'll go to see a live play instead of a movie.
Well, I have no idea if I'm losing any secondary audio...and couldn't care less, but I guess if this is true and someone likes to do picture in picture while watching a movie (which i can't get either), this would be a disadvantage._________________________________________________
I would agree with you for the most part I very rarely watch the features or commentaries on most disc but the HUD on Transformers and the blue screen PIP on 300 was pretty cool.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
