Dolby TrueHD and DTS-HD?
Early B.
I have a Toshiba HD-A2 arriving tomorrow. Did some research and noticed that in order to get HD sound, i.e., Dolby TrueHD & DTS-HD, I need to have an AV receiver with HDMI connections. Is this correct?
How much better sounding is TrueHD & DTS-HD over regular DD & DTS?
The reason I'm asking is because a new receiver with HDMI connections would be a major upgrade for me from a cost standpoint. I'm happy with my Pioneer Elite 52TX, but it doesn't have HDMI connections. Is a new receiver worth purchasing just for the new HD sound formats?
Any other ideas or suggestions are appreciated. (Sure, I'd rather do separates, but it ain't in the budget right now.)
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Early, good question, thats why I went with the XA1 (for 5.1 analog out), I am in the same situation as you.
I feel your pain brotha.
We are always missing something.....darnett...Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Yeah, I went with the XA1 as well so I would be able to take advantage of 5.1 analog output to get the newer audio formats with my current 635.
Lot of good HDMI AVR starting to pop up, though. Good luck if that's the route you go! I don't notice a huge difference in audio quality and typically still run digital out from XA1 to my 635 cuz I prefer my HK's bass management.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I'd like opinions on this also. I have an A2, but don't want to upgrade unless the difference is significant.Things work out best for those who make the best of the way things work out.-John Wooden
I am a big skeptic when it comes to people saying that changing cables makes the sound better, etc.... but... when I switch from DD-Plus to Dolby TrueHD, I can hear the difference. The biggest improvement is in the bass (subwoofer channel) and rear surrounds. It's much more clear, bass is tighter.
And yes, that's exactly the reason why I picked XA1 over A2 (analog audio outputs - to listed to Dolby TrueHD and DTS-HD).Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
That's pretty interesting. I've been looking to upgrade one of the TV set ups in the house and it's interesting to know that there's an audio expansion along with HD.
Wow. The XA2 costs about $300 more than the A2.
The better option for me would probably be to sell my AVR and put the proceeds plus $300 towards a new or used AV receiver. That is, of course, if the sound quality is going to be significantly better.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I'm in the same boat with my A2 and PS3.
I've researched little bit but not extensive. Currently there are receiver from Onkyo and Denon that will decode HD audio tracks.
I have Denon AVR-3803 with Outlaw 770 amp so I'm planning to upgrade to a preamp/processor rather than dumping money on a receiver if i get all the features i need
Integra DTC-9.8 has excellent feature for $1600 with Reon upscaling chip. But you can only order it throught the dealer.
http://integrahometheater.com/model.cfm?m=DTC-9.8&class=Separates&p=i
http://www.onkyopro.com/model.cfm?m=PR-SC885P&p=f&class=Preamplifier
I'm still undecided. I still want to wait and see what other comes out with especially Outlaw. They are planning an HDMI preamp around summer 2008.
But the wait seems long.
I'm planning to start a separate thread if its not already done so.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
malikarshad wrote: »I've researched little bit but not extensive. Currently there are receiver from Onkyo and Denon that will decode HD audio tracks.
If all HD-DVD players include HD audio decoders, is it necessary to buy a receiver that also decodes HD audio tracks? They're more expensive. I'm thinking as long as an AVR has HDMI capability, it should be OK. Is that correct?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
AFAIK, so long as it has hdmi, it'll recieve the toshiba's signal as pcm, effectivelly giving you the same thing as trueHD.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Its good to see that HD DVD and Blu-ray are really catching on around here.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
My comments above were regarding DD+, not Dolby TrueHD or DTS-HD. I need to figure out which discs are TrueHD and play those. DD+ sound like DTS to me; slightly better than DD, but not a big difference.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
I will test mine tomorrow. With Transformers, which I believe has DDTrueHD. DDTrueHD through 5.1 analog compared to DD+ through coax digital.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Due to the low price, I may consider purchasing one of these in the next few months to deal with the HDMI issue:
http://www.emotiva.com/lmc1.html
I wonder if this thing will sound better than my current AVR.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Transformers audio is awesome, but it's DD+, not TrueHD.
An unfortunate casualty of all the extras on this two disc set was a high-res audio track -- a strike against HD DVD's 30GB capacity -- although the Dolby Digital 5.1 Surround mix that is present got the all-important "reference material" nod from several outlets.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
I just read...Damn.. Alot of people upset. The benchmark movie with no lossless audio...Sucks :mad::mad::mad:Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Nice Early..Even has a zone 2 amp..coolMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I guarantee you will not be disappointed with the DD+ soundtrack on TF if you have the analogs set up correctly.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
millerman 3732 wrote: »I guarantee you will not be disappointed with the DD+ soundtrack on TF if you have the analogs set up correctly.
But DD+ would be the same on coax digital as it would on analog ..correct?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
NO!!! Your player, XA1 in your case, will DOWN CONVERT a DD+ track to DTS before it sends out via coax so your HK can decode it, it is not the same.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
millerman 3732 wrote: »NO!!! Your player will DOWN CONVERT a DD+ track to DTS before it sends out via coax so your HK can decode it, it is not the same.
Ok....
Its a good thing you screamed out the words NO and DOWN CONVERT...I would have missed those words for sure...:p:p
I never though we would be talking about down converting to DTS. When not long ago it was "man I wish there were more DTS tracks on DVD's":p:pMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Just making sure I had your attention.
Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Why not buy a HDMI switch instead of spending money on this just for HDMI switching. Its does not have decoding of HiRes audio.
You can get a cheap HDMI switch on monoprice.com or any other online stores.
That depends on if you will only have one source of HiRez format then you'd take analog out to your receiver. But if you have multiple sources then you'd end up using down converted signal for others. Moreover the receivers/processors will be capable of decoding bitstream as well as PCM signals.If all HD-DVD players include HD audio decoders, is it necessary to buy a receiver that also decodes HD audio tracks? They're more expensive. I'm thinking as long as an AVR has HDMI capability, it should be OK. Is that correct?
THe HD-A2 re-encodes the DD+ to DTS.
If the TV is 1080p I would suggest go with XA2 although with $300 price difference as you say. The XA2 is a an excellent upconverter at the same time it has 5.1 analog which is capable of outputting Dolby True HD, DD+ or DTS HD and also output 1080P that matches with the TV.
Both XA2 and XA1 is the best choice specially if there is no intent to upgrade the receiver just to experience hi-res audio. It will do the trick thru the 5.1 analog output. -
malikarshad wrote: »Why not buy a HDMI switch instead of spending money on this just for HDMI switching. Its does not have decoding of HiRes audio.
Really?
Will this work?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
The HDMI switch that was mentioned is only applicable if there 2 source of HDMI (ie Blu-Ray and HD-DVD) and 1 input through the TV. Other than that, there is no other function on it with regards to DTS-HD, Dolby TrueHD or DD+ sound.
OK, thanks.
Please show me a link to what I should be looking for.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I have not personally used it but if you are lazy like me I would choose the one with remote and built in equalizer.
like this
The only way you will experience DTS-HD, Dolby TrueHD or DD+ sound on a receiver that does NOT have HDMI input/output, you need to purchase either XA1, XA2 or A35. Those model of HD-DVD has 5.1 analog output. When you have those model, buy 3 pairs of analog cable and hook the 5.1 analog output from your HD player to the receiver.
The HD-A2 can decode hi-res audio but you NEED a receiver that has HDMI input/output. -
I think this will work using the HD-A2's toslink connection, but it's cost prohibitive...
http://cgi.ebay.com/GEFEN-COMPONENT-VIDEO-OPTICAL-TO-HDMI-CONVERTER_W0QQitemZ130165202337QQihZ003QQcategoryZ73390QQssPageNameZWDVWQQrdZ1QQcmdZViewItemHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
HDMI switches are just for HDMI AVR's or HDMI TV's. Those switches will not get you HDMI audio for a reciever like yours and mine with no HDMI input.
Until they come out with a HDMI/analog audio converter, there is nothing we can do, except buy a player with analod out.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
