Speaker Stands for LSi9?
bernardo
Hi everybody,
It's been a long time since my last post. Nice to see some of you are still around.
Do you think 26in tall stands are enough for LSi9s as rear speakers? (looking for example at Sanus SF26 @ $100. Also, none of the NF series support more than 25lb
Is it me, or there isn't anything out there taller that can handle the 31lb these weigh?
Before you ask
, I was looking for the 7s for rears but I just could not ignore the deal I got when tweeter left my area. And no, walls are not an option for me.
Thanks a lot.
Before you ask
Thanks a lot.
Post edited by bernardo on
Bernardo, have you been lurking around for the past 6 years?
This is what I use for LSi9:
http://www.moreentertainmentcenters.com/Sanus-SF30-b-SY0064.html
So far so good and still going strong for 4+ years.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
that`s what I`m using, but I`m going to 30 or 32" soon
I like the ones that polk suggested for the 7`sCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Not really, I started lurking around lately. Don't even remember when I stoped before. I guess I suddenly got too busy or other things caught my attentionBernardo, have you been lurking around for the past 6 years?
That's good to know, because those are supposed to withstand only 25lb...This is what I use for LSi9:
Are you happy with that height (30in) for rears? Or would you go to the 34in ones if you were looking now? -
I have both, 30" and 34" - for rears, I used 34" with LSi7 at one time, and also tried 34" with LSiFX. I definitely feel that for rears 34" is better. Just make sure that you don't have kids running around...I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Sanus Natural @30" for front. Plenty solid enough.
edit: Fronts are LSi9's @ over the rated weight, woops.-Ignorance is strength -
