Wiring my CSi40
thehalo8
thehalo8 Posts: 127
I just picked up the CSi40 that I have had my eye for some time now. I will eventually bi-wire it, but for right now I just want to hook it up and enjoy.
I have looked through many past posts and was unable to find another thread already discussing my question. I know if I want to bi-wire that I must take off the metal jumpers to keep from possibly harming my speaker. But does it matter which terminal I connect the wire to when the metal jumper is on? I would assume either the top or the bottom terminals would be fine since they will share through the jumper. If someone could let me know if it matters or not I would really appreciate it. Thanks.
Mike
Mains: Polk RTi70's
Center: Polk CSi40
Surrounds: Polk TC60i's
Sub: Polk PSW505
Receiver: Onkyo TX-DS696
TV: Samsung HLS 5687W 56"
DVD: Sony DVP S5300
Protection: Monster HTS 3600
Backup Battery: Belkin AP3080010
Post edited by thehalo8 on
  • danger boy
    danger boy Posts: 15,722
    edited February 2003
    does not matter. you are correct you can connect to either top or bottom. i flip a coin.. that's how i decide. ha ha ha heads top, tails bottom.
    PolkFest 2012, who's going>?
  • HBombToo
    HBombToo Posts: 5,256
    If you have some additional speaker wire you might want to try and remove the flat terminal straps and replace them with the wire.
    HBomb
    ***WAREMTAE***
  • mantis
    mantis Posts: 17,323
    Whatever kind of wire you use for your mains should be the kind of wire you should use for your center.
    Replacing the jumpers with the same wire is a good direction.Bi wire is the best.
    Dan
  • thehalo8
    thehalo8 Posts: 127
    Thanks for the quick replies. I chose the top terminals to connect the wire for now, and I am very pleased with it. I am using the same wire for all speakers throughout my system. I do not have anymore wire, so that is why I did not bi-wire my center channel. I just used the wire I was using on my old center channel. I plan on buying some more wire soon. How much of a difference does the bi-wiring actually do? I read posts about how it sounds better, but how much does it actually improve the sounds?
    Mains: Polk RTi70's
    Center: Polk CSi40
    Sub: Polk PSW505
    DVD: Sony DVP S5300
  • kberg
    kberg Posts: 974
    You'll get different answers to this question, ranging from "a world of difference" to "I can't tell the difference".
    Bottom line: Try it and let your ears decide.
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • danger boy
    you'll get a slight improvement in sound if you bi wire.. but like kberg said.. it's different with everyone. I found mine didn't sound louder or anything.. what I noticed was the sound to be more open and airy. fluffier, softer, warm and fuzzy-ier.
  • Tour2ma
    Tour2ma Posts: 10,177
    Mike
    True for bi-amp; Not true for bi-wire...
    More later,
    Tour...
    Vox Copuli
  • Dr. Spec
    Dr. Spec Posts: 3,780
    It is a good idea though, and failing to do so negates the purposes of bi-wiring, which is to eliminate cross talk between the terminals.
    SVS
  • Tour2ma
    Agreed Doc, I was just saying that speaker damage is not the reason.
    More later,
    Tour...
    Vox Copuli
