New amp
wodom1
With my decision to purchase an LSiC from AndyGwis, I'll need to pick up a new amp. I'm currently using an Adcom GFA 545 II to power my LSi15's, but I'd like to get a new five channel amp, however, I need something that will allow me to choose between two sources for my mains. I use a tube pre for music and my old Denon AVR for movies. It's a pain in the **** to switch back and forth now, as I have to unplug the pre-outs from the AVR every time I listen to music -- using a Y splitter on the amp input. Should I look for an amp with a source selector or go with a seperate piece of equipment for that task? I'm also going to start looking for a new HT pre with DTS/DD. Any/all advice is much appreciated. I'm 90% two-channel, 10% HT.
Josh
Josh
"I got into the music business thinking it was really radical, that it wasn't really a business at all, that it was a lot of people being artistic and creative. Not true, and it made me very depressed."
Thom Yorke of Radiohead
SOPA. Bow down before me, ****. Want a cookie?
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi30
Samsung LN-T4061F 40" 1080P LCD HDTV
Sony Playstation 3
Outlaw Model 990 Pre/Pro
Rotel 985 MK II
Rotel 1072 CDP
Soundstage Vacuum II tube pre
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi30
Sony Playstation 3
Rotel 985 MK II
Rotel 1072 CDP
See if you can get an HT bypass added to your pre. Or you could do it yourself- drill out holes for a new set of RCA's and a switch. Unsolder wires currently hooked to pre-out on your preamp & solder them to one input the switch and new set of RCA's to the other input on the switch. output goes to the your pre outs. then put denon pre out to that new set of RCA's.
Your y-cable is REALLY asking for trouble.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
That sounds effin' scarry!!!Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I don't have the time or know-how to mess with soldering anything. My tube pre is more of an entry-level pre, so I doubt I can get anything added to it. I'm looking at the Rotel RMB-1095 as a new amp, but does anyone have any other suggestions for how to split the amp between two sources?"I got into the music business thinking it was really radical, that it wasn't really a business at all, that it was a lot of people being artistic and creative. Not true, and it made me very depressed."
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi30
Sony Playstation 3
Rotel 985 MK II
Rotel 1072 CDP
Soundstage Vacuum II tube pre -
Adcom 555 or 555II are very nice amps and clean. To me they are the best bang for the buck.
engtazengtaz
I would think you could make some type of switch box with an a & b input then run the output from the switch box to the amp. You would need some sort of 3-way switch (or switches) some RCA jacks, etc. I would have to give it some thought. I can't see it being much different then the multi input boxes used for TV's that radio shack sells.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
