Yamaha YSP-4000 sound bar
bikezappa
bikezappa Posts: 2,463
edited October 2007 in Electronics
Any one heard this new 4th generation system from Yamaha?
By boss was looking to get a surround system for his girl friend's new 60" tv and I suggested the Polk sound bar system. He listened to both and was blow away by the yamaha. No wires.
Any opinions?
Post edited by bikezappa on
  • dorokusai
    dorokusai Posts: 25,624
    edited October 2007
    It sounds good in a small room but doesn't work well in large ones. I'd bet the Surround Bar 50 would be better demo.
  • bikezappa
    edited October 2007
    They have a small room. They will also get the sub with it.
  • dorokusai
    edited October 2007
    They should be fine.
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2007
    Haven't hear the new YSP4000 yet, but if it's like the YSP1100, I definitely prefer the SurroundBar. The Yamaha appeals to some people though because you don't need a separate receiver so no cables going from the receiver to the speaker bar. YSP's also aren't designed for corner placement of open rooms.
  • Face
    Face Posts: 14,340
    edited October 2007
    Probably not the loudest, but appears to dig very deep for a unit in it's price range.
  • bikezappa
    edited October 2007
    Thanks everyone. I strongly recommeded he get the 4000 system and also get the recommended Yam sub to match it.
    You hate to recommend something that doesn't make the boss look good.
  • beardog03
    beardog03 Posts: 5,550
    edited October 2007
    the Polk Soundbar is an awesome speaker..
    at PF we got to hear the demo..
    Throw some small rears fora large room and call it a day !!
    Not too sure about the Yammie one, but I hear it aint too shabby
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • bikezappa
    edited October 2007
    The Yammie 4000 is for my boss's ex wife who hates wires and complexity.
    The polk requires a reciever. The Yammie has a mic and auto sound set up and simple connections and sounds good.
    Done deal I think.
  • dorokusai
    edited October 2007
    I like the built-in DSP and amplification as it certainly opens up a new market of consumers. It wouldn't suprise me if you saw something like that from Polk at some point.
  • sirhc55
    sirhc55 Posts: 5
    edited October 2007
    The SoundBar is the preferred unit to use when you have an irregular shaped room. Yhe Yammies use the walls so are best suited to a theatre room with no windows and four equal walls. So, if you live in a box without windows go the Yammie:)
  • fireshoes
    edited October 2007
    bikezappa wrote: »
    Which Yamaha sub? If it is a YST-FSW100, DON'T LET HIM GET IT. They are absurdly bad. Be careful of any the subs with small boxes. They don't support much volume at all and distort and rattle a lot.
