Balanced cables
dholmes
After moving my eq around my xlr cables are tooo long, how do I get the ends off of the cable to make them shorter? Should I just forget about it & leave them the length they are?
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Anyone!!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Forget it and leave it the length they came with. They will be fine. If need be, coil them.
engtazengtaz
Thanks I guess thats why you use balanced cables because the length doesnt produce any lose of signal.My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
also, unless youve had some experience soldering i dont think it would be a good idea. the cable needs to be cut and then resoldered onto the end
