Onix SP3 or Jolida integrated amp
kelly001
kelly001 Posts: 10
edited October 2007 in Electronics
I'm looking to buy my first tube amp. :) I'm torn between an Onix SP3 or a Jolida integrated tube amp (model to be determined). Any advice or suggestions concerning these two options. I'm looking to buy used and spend around $500-600.
  • dorokusai
    dorokusai Posts: 25,661
    edited October 2007
    I believe both manufacturers are solid and I've owned alot of Jolida gear. The JD-202 was a standout but the hybrids are pretty nice as well.
  • Early B.
    Early B. Posts: 7,900
    edited October 2007
    Go with Onix. They can be had for $500. The Jolida 502B has more power, but is also more expensive. The Onix is built better, though.
    "God grooves with tubes."
  • kelly001
    kelly001 Posts: 10
    edited October 2007
    Thanks guys. I can only imagine that hooking an SP3 to a pear of 301-IV Bose speakers would be heresy? What speakers would you recommend to go with an Onix SP3 for under $600 a pair?
  • Early B.
    edited October 2007
    kelly001 wrote: »
    Floorstanders or bookshelf? New or used?
  • kelly001
    kelly001 Posts: 10
    edited October 2007
    Early B. wrote: »
    I have no preference. If floorstand it would have to be sturdy to withstand our toddler.
  • Early B.
    edited October 2007
    If you have a subwoofer, I'd get bookshelf speakers and set them aside when not in use due to the toddler. Most floorstanders under $600 probably won't be heavy enough to dissuade a curious child from trying to tip them over. Plus, you'll need to budget at least $100 for some nice speaker stands.
    There are literally hundreds of decent bookshelf speakers in your price range. Since this is the Polk forum, start with the Lsi9. And get the heavy duty metal stands from Parts Express and fill the column with lead shot.
  • kelly001
    kelly001 Posts: 10
    edited October 2007
    I'll check out the Lsi9's! Thanks!
    Do you know anything about the Klipsch Heresy speakers?
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2007
    I would get a pair of used Von Schweikert VR1's. You can get them for around $500. They are going fast though, since they were discontinued.
    SOPA
  • Early B.
    edited October 2007
    Zero wrote: »
    While this is a Polk forum, the Lsi series has no business being placed in the mix with low powered tube gear. That’s just a bad recipe no matter which you slice and dice it. The Lsi is a **** of sorts, and needs to be controlled. My own personal opinion on Jolidas house-sound aside, the amps just don’t have the cajones to satisfy the Lsi.
    Oh yeah. You're right about that.
    I think Polk made a mistake by making its Lsi series as hard to drive as it is. I fear that many people who own them are not feeding them with enough power. I wonder how many former owners didn't like them because of this issue.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Here are some alternatives http://www.pacificvalve.us/VTAmps.html
    Shanling makes a nice hybrid with 6922 input tubes.
    Many times you can get better prices on these amps from other places.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Here is an alternative to the Jolida Hybrid http://www.pacificvalve.us/BDC222.html
    It doubles power into 4 ohms.
    I has a jolida 3 channel tube/mosfet hybrid, liked it too, just a little glare though in upper mids on my 801's.
    The Bada seems better made, with better parts.
    Has Solen and Wima's in it.
  • kelly001
    kelly001 Posts: 10
    edited October 2007
    ka7niq, thanks for the suggestions. I'll look into them (though I kind of have my heart set on the Onix at this point even though I'm not a fan of its esthetics).
    Anyone care to comment on Klipsch Heresy speakers?
  • dorokusai
    edited October 2007
    I have an Onix SP3 MkII for sale in the flea market if you're interested. You can't PM yet so drop me a line to my email, dorokusai@verizon.net
