Onix SP3 or Jolida integrated amp
kelly001
I'm looking to buy my first tube amp.
I'm torn between an Onix SP3 or a Jolida integrated tube amp (model to be determined). Any advice or suggestions concerning these two options. I'm looking to buy used and spend around $500-600.
I believe both manufacturers are solid and I've owned alot of Jolida gear. The JD-202 was a standout but the hybrids are pretty nice as well.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Go with Onix. They can be had for $500. The Jolida 502B has more power, but is also more expensive. The Onix is built better, though.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks guys. I can only imagine that hooking an SP3 to a pear of 301-IV Bose speakers would be heresy? What speakers would you recommend to go with an Onix SP3 for under $600 a pair?
Floorstanders or bookshelf? New or used?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I have no preference. If floorstand it would have to be sturdy to withstand our toddler. -
If you have a subwoofer, I'd get bookshelf speakers and set them aside when not in use due to the toddler. Most floorstanders under $600 probably won't be heavy enough to dissuade a curious child from trying to tip them over. Plus, you'll need to budget at least $100 for some nice speaker stands.
There are literally hundreds of decent bookshelf speakers in your price range. Since this is the Polk forum, start with the Lsi9. And get the heavy duty metal stands from Parts Express and fill the column with lead shot.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I'll check out the Lsi9's! Thanks!
Do you know anything about the Klipsch Heresy speakers? -
I would get a pair of used Von Schweikert VR1's. You can get them for around $500. They are going fast though, since they were discontinued._________________________________________________
While this is a Polk forum, the Lsi series has no business being placed in the mix with low powered tube gear. Thats just a bad recipe no matter which you slice and dice it. The Lsi is a **** of sorts, and needs to be controlled. My own personal opinion on Jolidas house-sound aside, the amps just dont have the cajones to satisfy the Lsi.
Oh yeah. You're right about that.
I think Polk made a mistake by making its Lsi series as hard to drive as it is. I fear that many people who own them are not feeding them with enough power. I wonder how many former owners didn't like them because of this issue.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Here are some alternatives http://www.pacificvalve.us/VTAmps.html
Shanling makes a nice hybrid with 6922 input tubes.
Many times you can get better prices on these amps from other places. -
Here is an alternative to the Jolida Hybrid http://www.pacificvalve.us/BDC222.html
It doubles power into 4 ohms.
I has a jolida 3 channel tube/mosfet hybrid, liked it too, just a little glare though in upper mids on my 801's.
The Bada seems better made, with better parts.
Has Solen and Wima's in it. -
ka7niq, thanks for the suggestions. I'll look into them (though I kind of have my heart set on the Onix at this point even though I'm not a fan of its esthetics).
Anyone care to comment on Klipsch Heresy speakers? -
I have an Onix SP3 MkII for sale in the flea market if you're interested. You can't PM yet so drop me a line to my email, dorokusai@verizon.netCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
