Hk Ez-set
hexumjunkie
hexumjunkie Posts: 191
Recommend I Run This? I Have Had The Hk635 For A Few Years And Never Had? Will This Make It Sound Tons Better? I Have Made A Few Adjustments From Time To Time.....sorry Bout The Caps
Post edited by hexumjunkie on
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Run it hex..you will be pleased. You can do A/B test in the OSD.
    If not pleased then adjust the xover settings and rerun it in manual mode.
    MY EZ/EQ set the distance level almost exactly as my SPL meter. And it sets delay.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2007
    forget EZ Set. Go to RShack and throw some coin on a sound level meter - the analog one. And a Video Essentials disc. The only room calibration setup I trust even half-heartedly from an AVR is Pioneer's MCAAC.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    aaharvel wrote: »
    forget EZ Set. Go to RShack and throw some coin on a sound level meter and a Video Essentials disc. The analog one. The only room calibration I trust even half-heartedly is Pioneer's MCAAC.
    But EZ Eq also does a great job on eq'ing the room. At least use it for that and recheck the levels with the SPL.
    If you dont like it...do a reset and your back to square one
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Kex wrote: »
    Why the analog one rather than the digital one?
    To me the analog is actually easier to read and operate.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Ern Dog
    Ern Dog Posts: 2,237
    edited October 2007
    I found the room EQ adjustment to help improve the sound especially with my sub. It totally cleaned up the bass and tightened it. I found my (analog) Radio shack SPL meter to do a better job of adjusting the channel levels.
    I found an even bigger improvement when I listened to music in stereo mode with the DSP turned off. This can only be done using rca cables to connect the cd player.
  • SDG16H
    SDG16H Posts: 3
    edited October 2007
    Just got my hands on the 247 - I wired it all up - put everything back in place, placed the mic at head height where I sit and closed any doors that affected the dynamics. Turned it on and let it rip. Thought it did a great job. The only change I made was to move the crossover to 120Hz from the 100Hz that it picked.
    Upgrades will soon see a Csi5 and Rti10's...and will rerun it each time...
    Cheers
