Pairing with Yamaha RX V1800
wronguy
wronguy Posts: 1
edited November 2007 in Speakers
Hi, I was just wondering what you guys and gals think about pairing Polk RTi4 for front and back, CSi3 for the center and a PSW303 sub with a Yamaha RX V1800, new to this, info info would be appreciated
Post edited by wronguy on
  • mantis
    mantis Posts: 17,500
    edited October 2007
    It sounds like the start of a nice system. It seems to have some balance. Nothing wrong there man.
    Dan
    Dan
    tonyb Posts: 33,072
    edited October 2007
    Just don't try sticking it in a large room friend.Your good to go.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I just got my Polk speakers as the first part of my new Home Theater 'project'.
    I decided to hook up a pair of RTi4s and the PSW303 to my current/ancient 'stereo' system just to see what they would sound like.
    My current stereo set up is:
    Adcom GFP-555 Preamp
    Carver M-1.0t Power amp
    Sony DVP-NS300 DVD
    Koss CM/1030 Speakers
    I disconnected the Koss Speakers and first went with just the RTi4s on a pair of 30 Sanus Natural Foundation stands separated by about 8 ft and 1 ft off the wall.
    I popped in Pink Floyd's Dark Side of the Moon to give these speakers a first listen to and sat on the sofa at a direct midpoint between the speakers about 10 ft away.
    I was pleasantly pleased with the sound of just the bookshelf speakers.
    The sound was open, detailed, with a 'soundstage' that was an improvement over the Koss speakers (whose big attraction is their efficiency and power handling).
    But, as has been noted elsewhere, the low/mid bass of the RTi4s...well...adequate is a suitable term to use.
    I then hooked in the PSW303, placed it just to the inside of the left front speaker and about a foot off the wall, then made some adjustments to the low pass and volume to be about in 'the middle'.
    I restarted the CD and sat back down again and was even more pleased/amazed at the sound that now came from the setup!
    The dynamic range of the music was quite impressive (to me) - the PSW303 really gave a solid foundation to the RTi4s and made the combination feel relaxed and smooth from top to bottom.
    Forget the HDTV for now!! I'm rediscovering just the musical experience again of a much improved system!! :)
    And I got such a deal on the PSW and RTI4s - I'm very pleased!!!
    Erik
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Welcome to our new members. The RTi line is a great way to break into stereo or HT, great value and sound.
    Enjoy your new systems.
    RT1
